No heat passenger side, 2006 dts
Results 1 to 10 of 10
Cadillac DTS Forum - 2006 through 2012 Discussion, No heat passenger side, 2006 dts in Past Cadillac Vehicle Discussion; Hi everyone! I'm having issues now that it's cold with the DTS I recently bought, I have lots of heat ...
    Genn15 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Nov 2013
    19
    Hi everyone!
    I'm having issues now that it's cold with the DTS I recently bought, I have lots of heat on the driver side, mediocre heat in the rear zone, and it's ice cold on the passenger side. Anyone know what controls this would rather buy part from rock auto and do it myself than pay a fortune at local GM Pontiac dealer for guesswork (they are known for making shots in the dark, installing parts first asking questions later) I wish we had a real cadillac dealership I would say a precious few a year come through this place by my past experiences!
    Thanks for any help guys, greatly appriciated!
    TopherS is offline Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (98K mi.), '06 SRX V6-AWD (58K mi.)
    Sep 2011
    Portland, OR
    45
    316
    Re: No heat passenger side, 2006 dts
    I had a similar problem with a 2001 Park Avenue ... lots of heat on the driver side and A/C on the passenger side (this situation occurred in summer, when I didn't want heat at all).
    I don't know if the HVAC setup is the same with the DTS (my Park Ave only had a 2-zone HVAC system...not a 3-zone system). On my Park Ave, the HVAC system had 2 sensors in the air ducts, one going to each side. The sensors tell the head unit (in the dash) the temperature of the air going through the duct to its respective side ... and if necessary, it will tell the head unit to adjust the amount of heat/cold to send to that side to achieve the desired temp. My driver side sensor was faulty, creating a situation where the faulty sensor was "calling for" heated air on the driver side, so the head unit obliged and sent heated air to the driver side. The sensor was accessible from up under the dash (pretty easy to locate). It was replaced and all was well.
    I don't know if the DTS 3-zone HVAC system has the rear air ducts somewhat tied into the passenger side ... or if it is a split between the driver and passenger side. It may be that the passenger side failing is creating an inadequate heat situation in the rear zone.
    Hope this helps.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    There are actuators that control temperature for each zone. There is one for the right side up under the dash, they are a common failure and when they default they stick in one position or another.
    It is likely a bad temperature actuator.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    What ewill3rd said....
    Nov 2013
    19
    Awsome thanks, so it's accessed from underneath dash? Or behind glovebox?
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    The passenger side actuator I believe can be accessed by removing the glove box and some trim. It has been a while.
    I wouldn't be surprised if you could find a topic related to replacement.
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    441
    ewill3rd
    Seeing it says you’re a Cadillac technician but your profile says you’re a SERVICE ADVISOR/DISPATCHER.
    You have access to SI. The least you can do is look up in SI and send him the repair instructions and pictures
    on how to replace the Temperature Valve Actuator Right Side. It’s going to be more difficult job then you said.
    Nov 2013
    19
    That would awsome if possible
    satlite440 is offline Cadillac Owners Member
    Automobile(s): tec at brotherton cadillac
    Nov 2013
    48
    33
    Quote Originally Posted by danog View Post
    ewill3rd
    why is it the least he could do?????danog?????idk what you do for a living but do you give out free info to fourms related to your line of work????he already gave him the most common thing we see with dts hvac temp issues saving him at least an hour of shop diag timefrom a proficent shop and possably an unknown amount at a unskilled shop....isn't that enough???????i.m a caddy tech as well.. not to mention s.i. is copyrighted and all info is the property of gm and we are not authorized to release it.. and they moniter the i.p acess points...would you be willing to risk you job/income/and being taken to court and sued to help a stranger on a car fourm???????? the least youcould do sounded very entitaled and condecending..
    jazoo is offline Cadillac Owners Fanatic
    Jun 2012
    366
    Hey satkite440, I agree with you that the Caddy Tech cannot copy & paste the entire instructions and pictures from the copyrighted SI. He still can give Genn15 some guidance without divulging into details provided in the SI.
  13. Remove Advertisements
