Any advice for a DTS buyer ?
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Andrew224
  • 1 Post By Submariner409
Cadillac DTS Forum - 2006 through 2012 Discussion, Any advice for a DTS buyer ? in Past Cadillac Vehicle Discussion; Looking at a 2009 DTS with about 70,000 kilometers, anything special concerns or problems I should be aware of?...
    Cayman Went is offline Cadillac Owners Member
    Dec 2013
    British Columbia
    67
    1
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    Re: Any advice?
    Read the sticky posts just above this one, and look through the pages of threads here for items of interest. Same advice as buying any other used car - do your homework, and Caveat Emptor !
    adfundum is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac DTS
    Sep 2013
    17
    Re: Any advice for a DTS buyer ?
    It seems like strut bearings are a common issue along with the heated seats connector melting.
    Andrew224's Avatar
    Andrew224 is offline Cadillac Owners Fanatic
    Automobile(s): '41 67, '66 75, '02 Deville-L, DTS, DTS-L, XTS, '08 Escalade
    Apr 2012
    Plainfield, IL
    37
    132
    Put up the cash for a slightly newer one that is still under the original factory warranty.
    Kenwood likes this.
    jazoo is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Jun 2012
    366
    Seems to me a low mileage vehicle.
    I don't know how far is the Caddy located. If it's locally listed then I would strongly recommend getting it thoroughly inspected by your mechanic. If not then you can rely on: 1) the Car Fax Report and, 2) an inspection by a professional.
    Atavar is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS
    Aug 2013
    ND
    62
    211
    If the DTS is at a dealer get the extended warranty.
    Feb 2006
    57,139
    Quote Originally Posted by jazoo View Post
    Remember: CARFAX is a voluntary reporting database - usually, the only info you see is title transfers and required emissions inspections. Even flood damaged car slip past CARFAX quite frequently.
    "Honey, I smashed the Deville up pretty bad - Cooter and BooBoo fixed it with a hammer and some Bondo ! Tell CARFAX, will you ?"
    danog likes this.
  10. Remove Advertisements
