Can I get a softer ride?
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By Superjim
  • 2 Post By northstar1958
Cadillac DTS Forum - 2006 through 2012 Discussion, Can I get a softer ride? in Past Cadillac Vehicle Discussion; Let me explain...I know that most people nowadays want a ride that is controlled, sporty, firm, or what-have-you. I'm exactly ...
    TopherS is offline Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (97K mi.), '06 SRX V6-AWD (58K mi.)
    Sep 2011
    Portland, OR
    45
    304
    Let me explain...I know that most people nowadays want a ride that is controlled, sporty, firm, or what-have-you. I'm exactly the opposite. I like my cars to ride as if they are floating on air. I don't want to know what is going on with the road...I don't race my car around corners or anything like that, either. I want a ride that is serene...as little road-feel as possible. I have owned...and have driven...several cars that have this characteristic. They all had that serene ride...although there was a good amount of "float" or "bounce" with them; when going over frost-heaves and bumps ... but that does not bother me a bit. I think of my brother-in-law's 1991 Cadillac Sedan deVille or my old 1995 Buick Roadmaster or 1987 Cadillac Brougham when I think of the ride that I like.
    I know that car manufacturers have moved away from the floaty ride and toward the more controlled ride. I wanted a newer car with a lot of creature comforts...and I love that the DTS has it all...plus the many airbags and ABS that makes it safer than older cars. I love the style and how it seems to do everything for me...but I feel like the ride is too firm...a lot of jossling about over uneven/broken pavement...also makes my rear-seat vanity mirrors and sunroof sunshade rattle...which drives me mad.
    Here are some details about my car:
    * The car has 60K miles on the clock.
    * It is a LuxIII ... not a Performance Edition. It has the FE1 suspension.
    * I don't believe that the front struts have never been replaced. The rear air-shocks seem to be doing fine.
    * I have Vogue tires on the car (not by choice...they were on it when I bought it...but they are still good, so I haven't yet replaced them). They are aired up to 30-31 psi (cold). Sometime in 2014, I expect I will be replacing the tires...probably with Goodyear ComforTreds (I had those on my 2001 Park Avenue and loved them).
    My questions would be...
    * I suspect the car needs new struts...which ones would be best for the ride I'm looking for?
    * Is there a spring from a different vehicle that could interchange...but would have a softer spring rate than my current springs?
    I appreciate any help you can give. Cheers.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Can I get a softer ride?
    When I think of smooth rides, I remember my '84 Fleetwood Brougham deElegance..
    I agree that the newer cars are much safer and a lot more controllable than the older ones, but for pure comfort and isolation from the road, the old ones were much better.
    I wouldn't think that a 2008 with only 60K on it would need new struts... but you may well be right, it is YOUR car after all.
    I may be wrong, but I think there is only ONE strut for the front of your car... the same thing that is on it now.
    Same for the rear.
    I have 137,000 on mine and the struts and shocks are still the factory original ones.
    All that being said, I have the Performance Edition and run 34/35 PSI cold in mine, which has 245x50x18 tires on it.
    That is a lower profile tire with more air pressure than you are running, so it SHOULD BE a rougher riding tire.
    We have some pretty bad streets down here but I have NEVER had my sunroof sunshade rattle, and I drive fairly briskly.
    I have saw a number of complaints about the vogue tires on various forums that I frequent...
    That "MAY" be part of the problem, but of course, the only way to know that is to replace the tires.
    An expensive proposition if it doesn't help much.
    I don't think there are any softer springs for it either... unless the Buick Lucerne springs would fit.
    The Lucerne is a cousin to the DTS... but maybe uses softer springs... I don't know.
    Caddilack likes this.
    northstar1958 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    63
    I'm like you TopherS, I like the smoother ride. I also have a park avenue with the comforteds and love them. When it came time for new tires on the 2006 DTS i opted for the only thing i could change. I went to a "zero plus" tire....I swapped the 235/55/17s for 215/60/17s....alittle more rubber height between the road and the rim along with a 1/2 inch less width on the road. It made some difference along with less road noise. I'm not concerned about pushing it 90 mph thru corners...its all about the ride, and it helped alittle.
    northstar
    Gomaz and Caddilack like this.
    StuJac's Avatar
    StuJac is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 DTS Lux III
    Jan 2007
    Southeastern PA
    587
    I also get the sunshade/moonroof rattle when going over bumps. So does my buddy in his 09 and his previous 06. When mine was in for service a few years ago they gave me an 07 with a moon roof and it too had a slight rattle when going over bumps.
    Tomko's Avatar
    Tomko is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III (assembled January 31, 2008)
    Jul 2007
    South of 46
    270
    You are describing the ride quality I too seek.
    A Lux lll was the best way to go back in the day.
    If you are not pleased with your current experience, I suggest you ditch those vogues and go back to the michelin factory tire.
    The key is to have them road force balanced on a Hunter gsp9700 by someone who knows how to get your road force down to say 15 pounds or less per tire. It will take time to find someone truly competent in the use of this machine but it will be worthwhile.
    When I had mine done it took about 30 minutes a tire to precisely match and balance each one - and cost me ~$400 - but every time I drive the car I know it was money well spent.
    The tires left the factory balanced by true professionals on similar machines. So if you still have factory tires and wheels that have never been opened up for a repair, please don't rebalance them.
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,497
    Put a set of 16" wheels on the car and get an appropriately sized tire to match your OEM size outside diameter. This will likely be the easiest way to get a softer ride.
    You get some tires that have a taller softer sidewall than OEM tires and you will add to that floaty ride. You already have FE1 springs (which are the softest available) so there isn't much you can do unless you go full air bag suspension.
    I was able to put my 01 Monte Carlo SS 16" rims on my 02 Deville DTS (which came with the 17" chrome blades) without any clearance issues as my winter tire setup.
    Seeing as how the 06+ DTS kept the same chassis as the 2000-2005 it should work.
    Assuming the rims used on your DTS are 17":
    Code:
    Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
    235/55-17         5.1in  13.6in    27.2in         85.4in        742        0.0%
    215/65-16         5.5in  13.5in    27.0in         84.8in        747       -0.6%
    Or if you have the 18" wheel option:
    Code:
    245/50-18         4.8in  13.8in    27.6in         86.9in        730        0.0%
    225/65-16         5.8in  13.8in    27.5in         86.4in        733       -0.5%
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    I don't think DTS can it 16s. They got the same jl9 option the STS has.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    And balancing has absolutely nothing to do with a softer ride.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,497
    Quote Originally Posted by 1BadCadSTS View Post
    I figured that since he had the Lux package and not the Perf package they would fit. I would have thought the base brake package (from the STS) would be the base on the DTS, and that it would have been likely for them to do a carry over from the Deville.
    Did the 06+ DTS come with 16" wheels in any trim level?
    Sep 2010
    East Boston MA.
    29
    26,325
    I know several years back, a few Seville owners installed DTS front rotors and calipers, and those with 16" rims had to install 17,s to fit the brakes.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,497
    All I can say is that the OEM 16"s from my Monte Carlo SS Pace Car fit on the 2002 Deville DTS without issue as my winter tires for 2 of the 3 winters I drove the car. (3rd winter the treadlife left on them wasn't worth the swap).
    A 16" with the proper offset would have likely fit those sevilles (not necessarily Cadillac OEM rims).
    So since the chassis was a carryover from 2000 for the new DTS it doesn't seem like much of a stretch that the Performance car of the 2000-2005 model would have its brakes used as the base for the 2006+ model.
  14. Remove Advertisements
