passenger seat move extension - move seat 3" further back
Results 1 to 13 of 13
Cadillac DTS Forum - 2006 through 2012 Discussion, passenger seat move extension - move seat 3" further back in Past Cadillac Vehicle Discussion; Hi, my wife is not comfortable in the passenger seat and is pressing her knees against the console. Has anyone ...
    pschalow is offline Cadillac Owners Member
    Automobile(s): DTS 2008
    Dec 2009
    76
    Hi, my wife is not comfortable in the passenger seat and is pressing her knees against the console. Has anyone experience in extending the electric seat movement to go further back 2" or better 3"? She is not driving and nobody sits behind her on the back seat.
    Thanks in advance for your help and ideas.
    MrZoSo is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Mar 2010
    112
    Re: passenger seat move extension - move seat 3" further back
    I don't understand. The passenger seat can accommodate a person over 6ft 7 and has TONS of legroom. Is something wrong with the seats function?
    Atavar is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS
    Aug 2013
    ND
    62
    211
    Agreed. I am 6'1" and I have to move the seat forward a lot so my feet can touch the firewall (makes sitting more stable) and even then I have lots of knee space.
    I did have relocater rails like that for my XJ6L so maybe someone makes them for cadi.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    pschalow, The (unmodified) passenger seat in a late DTS will (should) go back far enough to allow her to have to stretch to even touch the dash/glove box area. I'm 6'3" and can move it back far enough and lower the back enough to fully recline...... and I can come close to that in my STS.
    Dec 2009
    76
    Dear Submariner409, thanks for your reply and your thoughts. I didn't wanted to get into details, but my wife has a weight issue, that's why we have the DTS with the bench and now she touches the middle console and sometimes lowers the air to 60 degrees - ha. So, if anybody had a technical solution on how to bring the seat further back, she would sit much more comfortable. I would appreciate any ideas a lot - thanks.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Pschalow, I have had a friend who is nearly 450 pounds in the passenger seat of my Seville. Their knees were not close to touching the dash. Unless someone were quite tall, as well as being heavy, I don't see the seat not being able to go back far enough to accommodate them. My suggestion would be to move the seat as far back as it will go, and measure the distance between the rear, bottom of the front seat, and the lower rear seat cushion. Another member could do the same, and you could find out if your seat is moving as far back as it should be.
    There really isn't any way to get greater travel out of the stock seat rail. Because of how it mounts to the floor, it can't simply be mounted further back. And there's no way to just extend the track.
    Cadillacman916 is offline Cadillac Owners Member
    Automobile(s): 07dts perf. 04 dts,06 dts limo,11 dts, 13 escalade, 13 xts
    Jan 2013
    Sacramento, ca
    31
    14
    I bet the problem is the seat rails are blocked somehow... Happened to me before. To fix it i gently pulled the plastic shroud around the seat off to inspect the rails, and a mangled quarter fell out.. havent had a problem since.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    I'm just 5 foot 8, but with the seat all the way back... I can stretch my legs straight out and not touch the firewall...
    Aug 2013
    ND
    62
    211
    Your wife might actually be more comfortable in the back seat with the front seat all the way forward. She would have a lot more room that way.
    If her condition is likely to be permanent and it were me I would go so far as to consider removing the front passenger side of the split bench seat entirely.
    It is a shame that those of us outside of societies norms often have to go to extremes to workaround problems.
    If there is a custom car or truck shop or even a good body shop in your area they should be able to relocate the seat aft for you. A *good* custom interior shop could even remove half of the back seat and finish everything off to look factory. Not cheap but possible. Being different is often expensive.
    Airbags are another consideration I am not expert enough to offer advice on.
    Sep 2010
    East Boston MA.
    29
    26,323
    Relocating the seat would be VERY labor intensive. The front of the seat "hooks" into slots besides a forward crossmember? while the rear of the seat bolts into another crossmember on one side, and into the sill panel on the other. For it to work, a second set of mounts would have to be installed/fabricated into the sill panel and center hump, a rear left "mount' would have to be fabricated, and the sill panel would have to be modified to accept the right rear seat track bolt. And it would all have to be at least as strong as stock.
    Aug 2013
    ND
    62
    211
    Oh, I do not doubt that it would be intensive *and* expensive. I just said it would be "possible". If it were me and my wife though, and it sounds like it is going to be a long term issue, I would consider it. I bet it wouldn't be as expensive or any more intensive than adding a handicapped lift chair to replace the passenger seat, and that is pretty commonly done.
    Take a look at this, it might be a good solution.
    and here's a seat base that will let you keep the factory seat and gain up to a 20" setback.
    http://bdindependence.com/
    Sep 2010
    East Boston MA.
    29
    26,323
    I know the second option you posted is designed specifically for full size vans (as is, unfortunately, most handicapped/"mobility" equipment). The second one may work, but the problem would still be mounting. The seat swiveling out of the car is very helpful, however, the stock seat would probably not be able to swivel out of the car because if it's size. Usually, a smaller, generic seat is used, and they tend to be uncomfortable, especially for a larger person.
    Hopefully, for the OP, it's just an issue with the stock seat not traveling fully back.
    HASSAN4477 is offline Cadillac Owners Member
    Automobile(s): 06 DTS PERFORMANCE
    Oct 2012
    43
    @pschalow being that the front of the seat tracks are hooked and not bolted in the floor something would have to be fabricated to move it. Have you ever considered removing the console all together you can remove the top and keep the seat filler bottom. I know it's not moving it back but it will give her a little more comfort for the time being, also if you live in Michigan private message me I own an auto upholstery shop in Detroit I would be able to move the seat for you!
  16. Remove Advertisements
