P0332 - knock sensor - 2006 DTS performance
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Chadillac182
  • 1 Post By Superjim
Cadillac DTS Forum - 2006 through 2012 Discussion, P0332 - knock sensor - 2006 DTS performance in Past Cadillac Vehicle Discussion; Tore into the motor today.. Removed intake to get at knock sensors. Also replaced the thermostat. Found a little friend ...
    Chadillac182's Avatar
    Chadillac182 is offline Cadillac Owners Member
    Automobile(s): 98 Concours, 01 STS, 02 deville, 06 DTS performance, 07 Esca
    Mar 2009
    Ontario, Canada
    35
    65
    Found a little friend making a nest under the intake!!! Ate the knock sensor harness...all fixed now. Running perfect! All engine codes gone!!!!
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: P0332 - knock sensor - 2006 DTS performance
    Good job...
    Was a mouse living under the intake ???
    That's really weird...
    Mar 2009
    Ontario, Canada
    35
    65
    Ya!! Unreal.. Chewed up my wire harness to make a nice nest
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by Chadillac182 View Post
    Is there any way to seal the intake so he can't get back in there and do it again ??
    Mar 2009
    Ontario, Canada
    35
    65
    I'm not 100% sure were he got in. But, the car was sitting for a while in storage before I bought it. I'm long gone from that area and the car is being driven...soooo hopefully that will do it!
    Superjim likes this.
    cadillacstar is offline Cadillac Owners Member
    Apr 2014
    4
    Did you have to torque any of the knock sensor bolts? I have to do this job on my 06 dts. I'm getting a P0332 along with a P0340 code.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by cadillacstar View Post
    Fix the cam sensor code first... It may be causing the other one.
    Apr 2014
    4
    Thank you...I will do.
    Apr 2014
    4
    I fixed the cam position code and still have the knock sensor code. It looks like something chewed up my cam position sensor wires, so I took off the power steering pump and reconnected the wires. That got rid of the cam position code but the knock sensor code is still there. It probably chewed the knock sensor wires too...I let the car sit for two years and this is what happens
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    That's the most likely thing...
    Check the wires going INTO / UNDER the intake before pulling the intake.
    I think there are two wiring bundles... one going to each knock sensor.
    If nothing is wrong with the external wiring, then pull the intake and you will see the knock sensors and wiring.
    cadillacstar likes this.
  13. Remove Advertisements
