DYI Replaced Front Struts 2006 DTS :)
Results 1 to 8 of 8
Cadillac DTS Forum - 2006 through 2012 Discussion, DYI Replaced Front Struts 2006 DTS :) in Past Cadillac Vehicle Discussion; Thanks for all the forum help on the symptoms of Front Strut bearing problems. 2006; 67,000 miles well maintained . ...
    lohimike is offline Cadillac Owners Member
    Aug 2011
    68
    24
    2006; 67,000 miles well maintained . Struts & Bearings started going about two months ago.
    I got a quote from Tread quarters for $800.00 dealer was more!
    Got my new unit struts from Dearborn Axel on Ebay@ 4198.00 pair!!
    It took about 2 hrs with breaks for the Pass side and 30 minutes for Drivers side.
    Went a lot easier to loosen outer tie rod.
    Big difference
    Mick Pendy is offline Cadillac Owners Member
    Automobile(s): 2006 DTS Performance
    Nov 2013
    18
    Re: DYI Replaced Front Struts 2006 DTS :)
    It was $4,200?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I'm assuming you have MRC?
    If that price isn't a typo,and all you blught was struts, you paid ~$3,000 too much.
    Aug 2011
    68
    24
    $198.00 sorry, my bad!
    caddydreamz is offline Cadillac Owners Member
    Automobile(s): 08 DTS
    Nov 2013
    9
    Does anyone know the correct way to put the bump stop on..position up or down??? On regular strut with coil springs??
    Sep 2010
    East Boston MA.
    29
    26,325
    It sits against the strut body, smaller end pointing up.
    phigment is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Nov 2010
    199
    Do you have a pic of the struts? Are they OEM? I'm soon going to be doing the same thing. Thanks.
    Nov 2013
    9
    I put the monroe sensa trac struts up front.. New to site will try to post a pic later,,and to moist cabbage the factorys i took off the bump stop was small end pointing down..the after market moog bump stop,the directioms had small end pointing up,so i did and idk but i think its wrong because i keep having suspension issuez
  11. Remove Advertisements
