Cigarette outlet always on?
Results 1 to 4 of 4
Like Tree3Likes
  • 1 Post By Superjim
  • 2 Post By Submariner409
Cadillac DTS Forum - 2006 through 2012 Discussion, Cigarette outlet always on? in Past Cadillac Vehicle Discussion; I noticed that when the car is parked, key not in the ignition, the cigarette outlet will still run power ...
    Caddilack's Avatar
    Caddilack is offline Cadillac Owners Member
    Jul 2013
    46
    I noticed that when the car is parked, key not in the ignition, the cigarette outlet will still run power along with the ashtray light on.
    Will it always run if I leave something plugged in? Or does it cut off power after 5 minutes or I lock the doors via the fob?
    Thanks for any insight.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Cigarette outlet always on?
    The light will cut off, but the actual 12v outlet is powered on at all times.
    My Radar Detector is plugged into mine and I have to remember to turn the detector OFF if the car is going to be parked for more than a week.
    The one under the drivers seat is always powered up also.
    Caddilack likes this.
    Caddilack's Avatar
    Jul 2013
    46
    Superjim,
    Thank you kindly for your input!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Maybe ........... In some models, in the underhood fuse box, the two 12V power outlets (cigarette lighter sockets) have 2-position fuses. In one position the outlets turn off with RAP. In the other position the outlets are hot at all times. The fuse legend is on the sticker in the fuse box cover.
    Superjim and Caddilack like this.
  7. Remove Advertisements
