2006 dts outer door handle removal
Results 1 to 4 of 4
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 dts outer door handle removal in Past Cadillac Vehicle Discussion; Hey everyone! Looking for the removal instructions for removing the rr outer door handle. Panel already off and inner panel ...
    yam700 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS LUX III
    Apr 2008
    Arnprior, Ontario, Canada
    23
    Hey everyone! Looking for the removal instructions for removing the rr outer door handle. Panel already off and inner panel removed.
    Apr 2008
    23
    Re: 2006 dts outer door handle removal
    Is their anybody out there? I was a gm tech for 18 years and don't have access to the manuals anymore. If someone could cut and paste the procedure that would be great.
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    443
    1 Rod, Outside Door Handle
    Tip: Release the handle rod retainer with a flat-bladed tool.
    2 remove 2 nuts holding Rear Side Door Outside Handle
    3 Tip: Transfer the handle rod to the new handle.
    Apr 2008
    23
    Thanks danog! Sure looks like the latch needs to be removed to access the one nut. Wish they would have cut a hole to access it.
    Yep the latch needs to be removed to access the nut behind it. Was sure hoping for an easier way.
  7. Remove Advertisements
