Results 1 to 4 of 4
Thread: 2007 DTS short in D Squib Circuit
    Teamster is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    3
    My 2007 DTS says "service parking assist". Scanner shows B0100 code "short in D squib circuit". I thought maybe it was #1
    sensor on left driver side so I changed it but it still has the same error code.
    Can anyone tell me where the d squib circuit is? Or what I need to do to fix the problem?
    Thanks
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: 2007 DTS short in D Squib Circuit
    I think the B0100 code "short in D squib circuit" is referring to the Airbag Circuit... may also being referring to the front end collision sensor.
    I am not certain of that.
    Oct 2007
    3
    Is your reference to front end collision sensor different than the 4 object sensors in the bumper? Is the airbag circuit, one circuit or a line of them.
    Quote Originally Posted by Superjim View Post
  5. #4
    danog is online now Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    443
    The scanner you are using may not be able to read the object alarm module?
    Here are all the codes for the object alarm module.
    DTC B0954 01 Parking Aid Front Sensor 1 (Left) Circuit—Shortto Battery
    DTC B0954 06 Parking Aid Front Sensor 1 Circuit(Left)—Signal Circuit Short to Ground or Open
    DTC B0954 08 Parking Aid Front Sensor 1 (Left)Circuit—Signal Invalid
    DTC B0954 21 Parking Aid Front Sensor 1 (Left)Circuit—Incorrect Period
    DTC B0955 01 Parking Aid Front Sensor 2 (Left Middle)Circuit—Short to Battery
    DTC B0955 06 Parking Aid Front Sensor 2 (Left Middle)Circuit—Short to Ground or Open
    DTC B0955 08 Parking Aid Front Sensor 2 (Left Middle)Circuit—Signal Invalid
    DTC B0955 21 Parking Aid Front Sensor 2 (Left Middle)Circuit—Incorrect Period
    DTC B0956 01 Parking Aid Front Sensor 3 (Right Middle)Circuit—Short to Battery
    DTC B0956 06 Parking Aid Front Sensor 3 (Right Middle)Circuit—Short to Ground or Open
    DTC B0956 08 Parking Aid Front Sensor 3 (Right Middle)Circuit—Signal Invalid
    DTC B0956 21 Parking Aid Front Sensor 3 (Right Middle)Circuit—Incorrect Period
    DTC B0957 01 Parking Aid Front Sensor 4 (Right Corner)Circuit—Short to Battery
    DTC B0957 06 Parking Aid Front Sensor 4 (Right Corner)Circuit—Short to Ground or Open
    DTC B0957 08 Parking Aid Front Sensor 4 (Right Corner)Circuit—Signal Invalid
    DTC B0957 21 Parking Aid Front Sensor 4 (Right Corner)Circuit—Incorrect Period
    DTC B0958 01 Parking Aid RearSensor 1 (Left Corner) Circuit—Short to Battery
    DTC B0958 06 Parking Aid Rear Sensor 1 (Left Corner)Circuit—Short to Ground or Open
    DTC B0958 08 Parking Aid Rear Sensor 1 (Left Corner)Circuit—Signal Invalid
    DTC B0958 21 Parking Aid Rear Sensor 1 (Left Corner)Circuit—Incorrect Period
    DTC B0959 01 Parking Aid Rear Sensor 2 (Left Middle)Circuit—Short to Battery
    DTC B0959 06 Parking Aid Rear Sensor 2 (Left Middle)Circuit—Short to Ground or Open
    DTC B0959 08 Parking Aid Rear Sensor 2 (Left Middle)Circuit—Signal Invalid
    DTC B0959 21 Parking Aid Rear Sensor 2 (Left Middle)Circuit—Incorrect Period
    DTC B0960 01 Parking Aid Rear Sensor 3 (Right Middle)Circuit—Short to Battery
    DTC B0960 06 Parking Aid Rear Sensor 3 (Right Middle)Circuit—Short to Ground or Open
    DTC B0960 08 Parking Aid Rear Sensor 3 (Right Middle)Circuit—Signal Invalid
    DTC B0960 21 Parking Aid Rear Sensor 3 (Right Middle)Circuit—Incorrect Period
    DTC B0961 01 Parking Aid Rear Sensor 4 (Right Corner)Circuit—Short to Battery
    DTC B0961 06 Parking Aid Rear Sensor 4 (Right Corner)Circuit—Short to Ground or Open
    DTC B0961 08 Parking Aid Rear Sensor 4 (Right Corner)Circuit—Signal Invalid
    DTC B0961 21 Parking Aid Rear Sensor 4 (Right Corner)Circuit—Incorrect Period
    DTC B1008 42 Calibration Data Not Programmed
    DTC B1015 00 Vehicle Identification Number (VIN) InformationError
    DTC B1E3A 03 Sensor Power Circuit Voltage Below Threshold
    DTC B1E3A 07 Sensor Power Circuit Voltage Above Threshold
    DTC B0968 00 Parking Aid Indicator Circuit Short to Ground
  • You may not post replies
