2007 dts
Results 1 to 2 of 2
Cadillac DTS Forum - 2006 through 2012 Discussion, 2007 dts in Past Cadillac Vehicle Discussion; 2007 DTS with 47K knocking noise in steering system when you turn wheel to left or right 1//4 turn. You ...
    st.johns is offline Cadillac Owners Member
    Automobile(s): 2997 DTS
    Sep 2013
    1
    2007 dts
    2007 DTS with 47K knocking noise in steering system when you turn wheel to left or right 1//4 turn. You can hear this knocking at low speeds when turning corners. Occasionally MAY feel slight knock in steering wheel.
    Also have a knock or thud noise in the right rear when slight bumps are hit or when right side is higher or lower elevation from left side. Can hear this at low speeds and when backing up. Sometimes you hear it when pressing or releasing the brake.
    Hearing a rattle at low speeds that gets better when you open the sun roof.
    All of this started at about 36K. Put new set of tires on with alignment and it checked out ok. Have checked all shocks and all four brakes discs.
    HELP! Sick of this Cadillac.
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    Sounds like intermediate steering shaft. For the wheel knocking
