Daylight running lights not working??
Results 1 to 10 of 10
Cadillac DTS Forum - 2006 through 2012 Discussion, Daylight running lights not working?? in Past Cadillac Vehicle Discussion; My yellow DRL stopped working... The turn signals work, they flash when I lock or unlock the car... But instead ...
    jpoborsky is offline Cadillac Owners Member
    Automobile(s): 2008 DTS, 2000 Deville
    Aug 2012
    Jackson, TN
    52
    14
    My yellow DRL stopped working... The turn signals work, they flash when I lock or unlock the car... But instead of the drl coming on during day light the regular lights come come instead. I also turned off the auto lights and switched to manual but I get nothing... No lights then. What could the problem be? Is there a relay or some kind of fuse that would cause only the drl not to work? Or is this another huge cost?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Daylight running lights not working??
    Pay attention to your dash lights...
    If your dash lights are dim during the day... it is most likely the light sensor in the middle of the dash... right behind the windshield.
    If you don't have something covering it up... it probably needs replacing.
    The sensor being bad will cause EXACTLY the symptoms you are describing.
    Aug 2012
    Jackson, TN
    52
    14
    The dash board lites do dim and the headlights come on instead of the drl. Nothing is blocking the sensor. Also, I can not turn the drl on manually.. when done manually I get nothing.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by jpoborsky View Post
    That's the way it will work if the light sensor in the dash is bad or if there is a wire loose.
    Since it don't know if it is light or dark, it will default to dark mode and have the headlights on all the time.
    Aug 2012
    Jackson, TN
    52
    14
    Thanks.. is the sensor a DIY project?
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Hello jpoborsky,
    I apologize that you are experiencing this concern with your DRLs on your DTS. I do see that Superjim has given you some great advice. I am not sure if you plan on tackling the sensor as a DIY, but if you do plan on taking it into a dealership to have them look into this issue, I would be more than happy to assist you in working with them. Please feel free to private message if this is the route you would like to take. Keep us posted as well so we can know the outcome of this situation. Thank you very much for your time. I will be looking for your future posts.
    Gregory W.
    Cadillac Customer Care
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    I am not sure exactly what it entails getting it out.
    I don't know if you can reach it from below or if you have to take the dash pad off.
    TopherS is offline Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (99K mi.), '06 SRX V6-AWD (59K mi.)
    Sep 2011
    Portland, OR
    45
    326
    Jim is exactly right about sensor...I've had to replace sensors in 2 other cars...the systems are set up to default to "dark" if the sensor isn't telling the system that it's light out.
    But in response to your DRLs - I've noticed that, in my car, when I turn the Twilight Sentinel system to "manual", the DRLs do not come on. I believe that they are integral to the Twilight Sentinel system and not a stand-alone feature...so when you turn the Twilight Sentinel system off, you also turn the DRLs off.
    As an aside, I've never turned my Twilight Sentinel system off during daylight hours, so it is possible that...when the ambient light sensor is functioning properly...that in daylight hours, it will permit the DRLs to come on when the Twilight Sentinel system is turned off. I'm getting ready to leave work and it is still light out...I'll try it...and post back. Stay tuned...
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    If you turn the lighting knob all the way to the left (manual) the DRL will NOT come on.
    I keep mine off most of the time to keep from burning the top part of the light assembly.
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    455
    Daytime Running Lamps (DRL)
    The front turn signal lamps are used for DRL operation. The DRLs will operate only when the engine is running and the headlamp switch is in the AUTO position. When the DRLs are ON, no other exterior lamps such as the parking lamps, tail lamps, etc. will be ON. Also, the instrument panel will not be illuminated.
    DRL operation is determined by the ambient light sensor and the controlled by the body control module (BCM). The ambient light sensor is a light-sensitive transistor used to monitor outside lighting conditions. The BCM provides a 5-volt reference signal to the sensor. The sensor will vary this voltage signal between 0.2 and 4.9 volts depending on outside lighting conditions. The BCM monitors the ambient light sensor signal circuit to determine if outside lighting conditions are correct for either DRL or headlamp operation. When the BCM determines the conditions are met for DRL operation, it turns ON the front turn signal lamps in a steady non-flashing mode. Any function or condition that turns on the headlamps will cancel DRL operation.
    When the BCM detects low light conditions, it will turn OFF the daytime running lamps and turn ON the low beam headlamps as described above in Low Beam Headlamp Operation. The BCM will also turn ON the low beam headlamps in daylight conditions when the windshield wipers are turned ON.
    To get to the sensor you have to remove the Instrument Panel Upper Trim Pad
  13. Remove Advertisements
