Hard Shifts Between gears!!!!
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By HASSAN4477
Cadillac DTS Forum - 2006 through 2012 Discussion, Hard Shifts Between gears!!!! in Past Cadillac Vehicle Discussion; All, I have an occasional hard shift sometimes between gears. I read online that it could be my shift control ...
    tjwhite721's Avatar
    tjwhite721 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS, 1999 Cadillac Seville
    Jul 2008
    Bloomsburg,PA
    315
    All,
    I have an occasional hard shift sometimes between gears. I read online that it could be my shift control solenoid going bad. I already had my transmission fluid drained and replaced with new filter and gasket at 88k. I now have 92k on my car.
    Anybody had their shift control solenoid replaced?
    Thanks,
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    Re: Hard Shifts Between gears!!!!
    Have the hard shifts been on cold days before transmission is 'up to temperature'??
    Only 4 thousand miles on new fluid and this never happened previously?
    No codes?
    Some shops will run a Free diagnostic on trans. and check pressures, etc.
    Hopefully there are some guys on here that have been thru this before.
    Service Manual is in my broken computer that is out . . getting fixed for two months now. -->
    billbill1 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Aug 2011
    Liberty Mo.,Ocala Fl.
    74
    56
    I haven't had this trouble with my 2006 DTS, but I have had it with other GM's .
    The last was my Grand Daughter's, 1999 Chev Lumina, with 44 K miles, 2 months ago.
    This fix is worth a try, I feel it's one of those " can't hurts" .
    I use one bottle of "Lucas Transmission Fix", with clean fluid. Yours should be clean enough.
    Get a MityVac, any auto supply, suck out old trans fluid in the amount of the "Lucas Transmission Fix"
    bottles content, 12 oz, I think . Put in full bottle . Will need to run for a couple hundred miles, to get
    a good fluid mix. Lucas Transmission Fix, has a good reputation, in the industry.
    HASSAN4477 is offline Cadillac Owners Member
    Automobile(s): 06 DTS PERFORMANCE
    Oct 2012
    43
    My o6 dts shifted hard it when cold or under load it ended up being the trans mount take your lf wheel off and u can visually inspect it. The mounts on these cars are filled with fluid to offset torque and reduce noise so look for signs of a fluid leak near the mount
    tjwhite721 likes this.
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    681
    I hope they didn't flush you're tranny, drain ok , flushing system not a good idea. I thought filter was inside unable to simply replace without dropping tranny? you can drain pan and screens but I thought filter was a different story.
    tjwhite721's Avatar
    Jul 2008
    Bloomsburg,PA
    315
    There are two filters for the tranny. One inside the pan and another one inside the crankshaft??? That you would have to drop the training to get to. The more I think about it, it might just be a transmission mount.
  9. Remove Advertisements
