power steering fluid leaks
Results 1 to 8 of 8
Cadillac DTS Forum - 2006 through 2012 Discussion, power steering fluid leaks in Past Cadillac Vehicle Discussion; Power steering fluid is leaking. Thought it might be a hose/tube leak, but when the mechanic and I looked, the ...
    kellyb101 is offline Cadillac Owners Member
    Automobile(s): 2008 DTS
    Sep 2013
    67
    Power steering fluid is leaking. Thought it might be a hose/tube leak, but when the mechanic and I looked, the hose was dry. Leak seems to be coming from a plug on the rack. Anyone else have a similar problem? What's the solution?
    theduchessofpr is offline Cadillac Owners Member
    Sep 2013
    1
    Quote Originally Posted by kellyb101 View Post
    I have a DTS with a current power steering leak as well. No one could find where it was coming from, but finally the mechanic left the hood up and turned on the engine and turned the wheel abd sure enough we saw where it was coming from. It's wad my high pressure power steering line. That mechanic quoted me $360 to fix it, but I'm going to get a few more before I make a final decision.
    Hope this helps.
    pictchic's Avatar
    pictchic is offline Cadillac Owners Member
    Automobile(s): Seville 1994 STS
    Apr 2013
    Winnipeg
    13
    OMG! (( same problem. I just spent all afternoon checking over the line, then tried turning the wheel left right left then held her left for a bit and..... WHALAAA! She spewed.
    I'm thinking this is my return. But not sure. It's the hose that runs along the back of the engine. I own a 94 STS 4.6L.
    Anyone?
    BlueAngel#07's Avatar
    BlueAngel#07 is online now Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,092
    Re: power steering fluid leaks
    Leaped before I looked, just posted the same problem, just wondering, do you, or did you replace the belt?
    pictchic's Avatar
    Apr 2013
    Winnipeg
    13
    Nope. Haven't even thought about that. More worried about a hole in the hose.
    Sep 2013
    67
    Thanks for the notes. Mechanic and I both checked the tubing, thinking that'd be the most frequent cause of this type problem. Alas, no such luck. The seals on the rack were the culprit. Replaced the rack - problem solved. Seems to me like a rack wouldn't normally need replacement in 88k miles, but maybe I've just got higher expectations about quality than I ought to for the Cadillac brand.
    tjwhite721's Avatar
    tjwhite721 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS, 1999 Cadillac Seville
    Jul 2008
    Bloomsburg,PA
    315
    Did you think about using stop leak for the seals?
    jsorrell's Avatar
    jsorrell is offline Cadillac Owners Fanatic
    Automobile(s): Black 2009 Cadillac DTS Luxury
    Oct 2006
    New England
    33
    275
    Before you found the leak did you notice any changes in the steering? I have an issue with my steering it feels like the magnasteer isn't doing its job right and it really noticeable when you are turning the wheel at higher speeds. Feels like it fights back and pulses a bit and like it takes more effort than it should to turn. I also notice at parking lot speeds the wheel is just as stiff as it is at highway speeds :-/
  11. Remove Advertisements
