Radio/nav problem
Results 1 to 3 of 3
Cadillac DTS Forum - 2006 through 2012 Discussion, Radio/nav problem in Past Cadillac Vehicle Discussion; Yesterday my radio/nav screen went black, no audio at all. When I press the on/off button for the radio it ...
    jackd is offline Cadillac Owners Member
    Automobile(s): 05srx n*07 dts
    Nov 2009
    40
    Radio/nav problem
    Yesterday my radio/nav screen went black, no audio at all. When I press the on/off button for the radio it comes right back on. This
    happened several times throughout the day, always with the same results when pressing the on/off for the radio. Any ideas would be
    greatly appreciated. Thank You
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Radio/nav problem
    There is a way to REBOOT all of the electronic modules in the entire car.
    Sometimes ( lots of times) that will fix random electrical gremlins.
    Remove BOTH battery cables... negative cable FIRST...
    Touch both cables together for 5 seconds or so, making sure they have good contact with each other.
    This will drain all the capacitors in the system.
    While you have the cables off... undo the one bolted to the floor.
    Take a little piece of sandpaper and sand the paint away from the attachment point.
    It will then have a better ground.
    Re-attach the battery cables... negative cable LAST...
    You will have to do the window EXPRESS UP learn again and you MAY have to do the memory seat settings again.
    Sometimes they will forget the seat settings and sometimes they don't.
    Nov 2009
    40
    Thanks Jim, tried your suggestion without success, anybody else have any suggestions?
