2006 Dts-Where is the ECU
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Superjim
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 Dts-Where is the ECU in Past Cadillac Vehicle Discussion; I think I need a new ECU for different reasons. Can some please tell me where the ecu is located....Thank ...
    cadwilliam is offline Cadillac Owners Member
    Automobile(s): 2006 dts 4.6
    Sep 2011
    62
    54
    I think I need a new ECU for different reasons. Can some please tell me where the ecu is located....Thank you.
    crazcaddyguy's Avatar
    crazcaddyguy is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS Performance
    Aug 2009
    Denver Co.
    32
    131
    I believe and please someone chime in... but it's in the air cleaner box. You have to open it then pull the cover off, then you will see it by the front of the car.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: 2006 Dts-Where is the ECU
    The ECU very seldom goes bad....
    Why do you think you need a new one ??
    The ECU is "INSIDE" the cold air tube.... right behind the drivers side headlight...
    The Transmission Control Unit is mounted on the inside of the drivers fender right close to the master cylinder...
    It has a big blue connector on it.
    Sep 2011
    62
    54
    The reason I believe I need a new ecu it car will sometime run really rough. Then the car will raise the rpm up and down on its own until it corrects itself. Also the car will cut off on its own sometime and then will wont do it for awhile so basically the car will run incorrectly at times...what's your guys opinion??
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    That does not sound like the ECU...
    Go to some place (like AutoZone) that can read the codes.
    WRITE THEM DOWN and then post them here.
    We will help you decipher them and what they mean.
    crazcaddyguy likes this.
    Sep 2011
    62
    54
    No codes but sometimes a code for the oxygen sensor will come on and go off on its own. That's all...
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by cadwilliam View Post
    Check your INTAKE MANIFOLD bolts... make sure they are snugged down good.
    You may have a vacuum leak.
    Call around to some local garages and find someone with a TECH 2....
    A Tech 2 will read ALL the codes... The Autozone scanners can only read engine codes.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,687
    Hello cadwilliam,
    I see Superjim has offered advice for your situation. I am sorry you are dealing with a vehicle concern of it running rough. If you would like to further discuss your current situation, please reach out to us via private message and include your contact information, VIN and current mileage.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    Sep 2011
    62
    54
    I have attached a photo. I checked all my bolts and they a tight. Also I don't believe it would be a manifold issues because the problem is not consist enough but that may not mean nothing. In the attach photo there is a small pipe sticking out, it is black. Is there a hose that is suppose to be attach to that pope coming out of the manifold?
  12. Remove Advertisements
