DTS 2006 white/blue smoke from tail pipes
Results 1 to 6 of 6
Cadillac DTS Forum - 2006 through 2012 Discussion, DTS 2006 white/blue smoke from tail pipes in Past Cadillac Vehicle Discussion; I just bought a 2006 DTS for my son and have had nothing but problems with it. The motor runs ...
    Kirsa is offline Cadillac Owners Member
    Automobile(s): DTS 2006
    Aug 2013
    Long Beach, ms
    47
    8
    I just bought a 2006 DTS for my son and have had nothing but problems with it. The motor runs rough and burns gas like crasy....smoke coming out of the pipes all the time. Smells bad of gas. It does not run hot and I do not see any milky stuff in the oil. The transmission shifts rough too. Tried to check compression and the front cylingers from left to right read 170 psi, 185psi for the rest. It ran normal for 5 miles after we took out the plugs and tested the compression, but the problem returned and the engine check light came on O2 sensor. The engine has 103455 miles on it. would any of your experts come with some suggestions to my issues?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: DTS 2006 white/blue smoke from tail pipes
    Fix the o2 sensor...
    If it has never had the plugs changed... change them also.
    If the o2 sensor is bad... it will make it burn a lot more gas... and eventually damage the catalytic converter.
    Aug 2013
    Long Beach, ms
    47
    8
    Thank you for your response. Would it be the up or downstream sensor? I have found one "DENSO 234-4337 Oxygen Sensor-OE Style Oxygen Sensor" is that the right one. Does the difference in PSI on the front cylinders mean anything?
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by Kirsa View Post
    That small difference in PSI probably means nothing...
    You need the ERROR CODE to tell which sensor it is...
    I think your car has three of them... one on each bank of cylinders and one in the exhaust pipe by the catalytic converter.
    It "MAY" have two by the converter... one in front of it and one behind it.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,936
    Does this engine have a fuel pressure regulator (FPR) on the fuel injector rail ?? If it does, that is a prime suspect for rich fuel mixtures. It's a domed thingy with vacuum line, set into a receptacle on the fuel rail tank return line end. With the engine idling (engine cover off), pull the vacuum line off the FPR nipple. ANY raw fuel in that nipple or line means replacement.
    NAPA, RockAuto or Chris in parts at Rippy Cadillac over there >>>
    ......... but don't simply throw parts at it - a rich fuel mixture might well throw an O2 sensor code and the sensor(s) would still not be the culprit.
    here's a FPR from my 2002 - probably close in appearance to yours...............
    Aug 2013
    Long Beach, ms
    47
    8
    Thank you guys. I appreciate the suggestions.
  9. Remove Advertisements
