7.5 or 8 Quarts of Oil for the DTS????
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Like Tree1Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, 7.5 or 8 Quarts of Oil for the DTS???? in Past Cadillac Vehicle Discussion; Most NorthStar Engines call for 7.5 quarts of oil. However, why do I always need to add 8 quarts of ...
    tjwhite721's Avatar
    tjwhite721 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS, 1999 Cadillac Seville
    Jul 2008
    Bloomsburg,PA
    315
    Most NorthStar Engines call for 7.5 quarts of oil. However, why do I always need to add 8 quarts of oil? Every-time I go to the dealer to get my oil changed, I check it after they change it, it's always a half quart low. If I go to a local mechanic, he adds 8 quarts.
    What is the correct quart amount for the DTS?
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,722
    Re: 7.5 or 8 Quarts of Oil for the DTS????
    Hello tjwhite721,
    I researched this question and in your owner’s manual in chapter 5, page 101 it states that the capacity of your engine oil is 7.5 quarts. I hope this information helps! Feel free to private message me if you have any further questions or concerns. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    Andrew Armitage Guest
    Normal reading on the dip stick should be 1/2 way up the area marked full.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Half way up the hash marks is FULL (xxxxxXxxxxx)
    TulsaVic is offline Cadillac Owners Enthusiast
    Automobile(s): '08 DTS Performance (gone); '11 Jeep Grand Cherokee Summit; 2017 MB C300 Cabriolet
    Jan 2008
    Harrison, ME
    70
    829
    Just guessing: 7.5 for the engine, 0.5 for the new oil filter??
    tjwhite721's Avatar
    Jul 2008
    Bloomsburg,PA
    315
    Thanks everyone for your responses. I was used to measuring the oil using the old quarter quarter lines dip stick off my old SLS. Yes, the DTS has xxxxXxxxx as a measuring guide. So the big X in the middle is the FULL measuring? That is kind of odd to me.
    I would think the big X in the middle of the measuring groves to represent half a quarter or half a quart low and time to add oil.
    TulsaViv, that is what someone told me as well. The oil filter takes about 0.5. Not sure that is why it turns out to be 8 quarts???
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Bottom line: 7.5 quarts WITH (including) filter. Oddball - yes. My Ford 4.6 in the truck takes 6.5 - same operating range.
    The hashmark is the "operating range" of oil levels. The highlighted center X is the design desired level.
    In my 2002 I run the level in the bottom third of the hashmark and get just about 6,000 miles per quart of 5W-30 synthetic. No leaks, either.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Just a thought....
    Maybe the big "X" in the middle is correct if you are checking it when the engine is COLD...
    Don't know for sure... just a thought...
    Feb 2006
    57,180
    .............. and "cold" would be the desired level just after an oil/filter change............. no way will you or the Oil Doodle get that nice, clean new oil up to the normal 190 - 220 degrees in 2 minutes of idling.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    I just looked at the dipstick in my car...
    It does NOT have a highlighted or large X in the middle of of the hashmarks.
    The oil level is between 3/8 and 1/2 inch below the TOP hash mark...
    This is where it always is when the engine is cold...
    Hard to see in this picture... the oil is clean...
    Feb 2006
    57,180
    ........... and they seem to have changed the markings sometime after 2003 - the earlier 2000's dipsticks look like this ..........
    <==== ADD XXXXXXXXXX OPERATING RANGE ==============oo==============================O
    ........ and exactly 7.5 quarts including filter puts the level at XXXXXXXXXX
    (the two "o" marks are rivets)
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Now that you mention it... I remember the rivets in some of my older cars....
    Ludacrisvp likes this.
    jazoo is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Jun 2012
    366
    Quote Originally Posted by tjwhite721 View Post
    Page 101 of the Owners Manual defines capacities of various fluids. It clearly says that the capacity is 7.5 quarts for Engine Oil with Filter. I do not add more than the specified amount as I am afraid of the following shown on Page 5-41:
    Notice: Do not add too much oil. If the engine hasso much oil that the oil level gets above the
    cross-hatched area that shows the proper operating
    range, the engine could be damaged.
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,323
    The engine's not going to be damaged by an extra half quart of oil. Even a quart and a half over wouldn't do anything.
    Anything over 7.5 will be consumed fairly quickly. It's wasteful, that's why the capacity was initially reduced.
  17. #15
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,113
    ODDLY strange, ...I just got off the phone with my cadillac dealer in regards to what is full on the dipstick. I was told that the full range was at the top of the crosshatching on the DTS, and the difference between the center and the top was about a 1/2 quart,
  18. Remove Advertisements
