2006 Rear drivers side express window problem
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By teckguy
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 Rear drivers side express window problem in Past Cadillac Vehicle Discussion; Drivers side rear window will not express down from rear door switch but will express down from drivers control panel. ...
    teckguy's Avatar
    teckguy is offline Cadillac Owners Member
    Automobile(s): 2006 DTS (Titanium) 43,000 KMs
    Jul 2013
    Greater Toronto Area, Canada
    45
    Drivers side rear window will not express down from rear door switch but will express down from drivers control panel. Thoughts? Bad switch perhaps? Otherwise window works fine.
    Asguard726 is offline Cadillac Owners Member
    Automobile(s): 2009 DTS Platinum
    Sep 2012
    56
    Teckguy,
    I could be wrong, but I think the express down only operates from the main control on the drivers door. I think the passenger
    front will express down but the rear are just regular switches...seems like I read that somewhere...
    Dan
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Rears are express down from both front and rear switches.
    My guess would be a bad switch.
    teckguy's Avatar
    Jul 2013
    45
    Rears should express down, the passenger rear one does. Honestly I think the previous owner never used the back sears, my kids noticed the window issue. Any relays in the door by chance to check as suspect. I cannot find much other than the switch in Alldata.
    Sent from AutoGuide.com Free App
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,214
    Re: 2006 Rear drivers side express window problem
    It may need to be relearned. Hold the switch in the up postion for several seconds after the window reaches the top before releasing it and see what happens. Read the owner's manual.
    Don't mess with Binky Bear!
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Hello teckguy,
    I see you are getting some great info from the community, and I see that dkozloski has given you a suggestion to check the owner’s manual about relearning the feature to the windows. I have looked up that information for you in case you didn’t have your manual. In chapter 2, page 16, it states :
    “If the battery on your vehicle has been recharged, disconnected, or is not working, you will need to reprogram each front power window for the express-up feature to work. Before reprogramming, you will need to replace or recharge your vehicle’s battery. To program each front window, follow these steps: 1. With the ignition in ACCESSORY, ON, or when Retained Accessory Power (RAP) is active, close all doors. 2. Press and hold the power window switch until the window has fully opened. 3. Pull the power window switch up until the window is fully closed. 4. Continue holding the switch up for approximately two seconds after the window is completely closed. The window is now reprogrammed. Repeat the process for the other windows.”
    Please keep us updated if this works! Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    teckguy's Avatar
    Jul 2013
    45
    Good evening... Tried the relearn process as part of my diagnostics, it's exactly like my Corvette but no luck. I think I'll gamble on a new switch. I wonder if I could borrow the passenger side switch as a test before I order a new one? Thanks so much for the ideas guys!!
    Sep 2010
    East Boston MA.
    29
    26,325
    The switches are the same. Give it a try.
    teckguy's Avatar
    Jul 2013
    45
    Thanks!!
    teckguy's Avatar
    Jul 2013
    45
    Fixed! What a well designed switch, completely modular down to the circuit board. I cleaned the contacts with a pencil eraser and gently put everything together so the plastic parts clicked together during assembly and it's now perfect
    Superjim likes this.
  13. Remove Advertisements
