tilt steering wheel and trac. control?
Results 1 to 2 of 2
Cadillac DTS Forum - 2006 through 2012 Discussion, tilt steering wheel and trac. control? in Past Cadillac Vehicle Discussion; 2006 DTS with 83,000 miles, when you try to use the tilt wheel sometimes it does't work. cadillac says there ...
    fubar123 is offline Cadillac Owners Member
    Automobile(s): 06 DTS
    Jul 2013
    18
    2006 DTS with 83,000 miles, when you try to use the tilt wheel sometimes it does't work. cadillac says there are 3 possible choices, switch or motor or acuator. Has anyone come across this. Can any of these parts be cleaned with electronic cleaner for first choice. all 3 parts from caddy are about $225. also can you get to these parts without taking steering wheel off.
    One more question, traction control / service trac control dash light comes on sometimes (no codes) could it be a ground problem? Code for this is DTC P1915. I saw on Ondemand5/Mitchell you can buy a wire harness part # 24236023 and reroute it around scavenger filter and move magnet to a different location on bottom of pan, how hard is it to get to?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: tilt steering wheel and trac. control?
    I think your code P1915 would probably be in the PRNDL safety switch or related wiring...
    P1915 - Reverse Switch Circuit Malfunction
