2006 DTS Oil Leak
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 DTS Oil Leak in Past Cadillac Vehicle Discussion; I own a 2006 DTS. Started noticing some small drops of oil on the floor in the garage. Cleaned up ...
    ChrisRick is offline Cadillac Owners Member
    Automobile(s): 2006 dts
    Jul 2013
    7
    2006 DTS Oil Leak
    I own a 2006 DTS. Started noticing some small drops of oil on the floor in the garage. Cleaned up the engine as much as possible to try to find the source. Could never pinpoint the source but still getting some spots. It has gotten worse in the last week. One interesting thing I've noticed is that there is oil at the top left (when standing at the front bumper looking at the engine) getting on the radiator refill and even on the bottom of the hood. It looks like the leak is at the back of the engine towards the passenger side. I have an appointment in two days at the dealer was hoping to get a jump on what I can expect to hear.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: 2006 DTS Oil Leak
    My guess from your description.. and it's just a guess... is the rear valve cover / cam cover leaking.
    That is not uncommon.
    DevilleDeeman's Avatar
    DevilleDeeman is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Premium, Saturn Vue XR
    Sep 2008
    Ontario, Canada
    48
    480
    Two common leaks on these engines. 1. SuperJim mentioned above 2. Half case seal. Half case seal is usually a "seep" and burns off while you drive rarely leaving oil on the driveway though unless the seal is completely gone.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,600
    Oil being thrown onto the hood insulation and firewall - leaking power steering pressure line or pump shaft seal ???
    Engine oil level correct - in the middle of the XXXXXXXXXX hashmark ??? P/S fluid OK ??
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by ChrisRick View Post
    Hello ChrisRick,
    I see forum members have offered their advice on your situation. I apologize for any inconvenience the oil leak is causing for you. I see you are going to the dealer in two days. Please keep me posted on the outcome of the dealer visit. I can be reached via private message so we can further discuss the outcome and any concerns.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    Jul 2013
    7
    Quote Originally Posted by Submariner409 View Post
    I'm a true car novice so...
    I checked the power steering fluid and it's dry. I turned the car on and checked again and there is the correct amount. The oil level remain fairly constant. I turned the car on and let it run in the garage and there are no signs of any leaks.
    There is a streak of oil on the hood insulation that seems to have been thrown there by oil hitting the belt on the passenger side of the engine.
    Feb 2006
    56,600
    That's most likely a P/S pump shaft leak. With the engine OFF the P/S fluid level should show on the bottom part of the little dipstick hashmark.
    Maybe - maybe - a crankshaft front seal leak (harmonic balancer) but that's a rare occurrence in these cars. A leaking cam cover seal would simply weep oil down the right side (rear) of the engine.
    Jul 2013
    7
    so perhaps PS fluid rather than oil? thank me latter for the hearty belly laugh you're going to have at this next question-
    how can I tell the difference? Does PS fluid also cause water to bead?
    Sep 2008
    Ontario, Canada
    48
    480
    Being an oil based product PS fluid would bead, to tell the difference from oil and PS fluid would be the color or smell. If you are experiencing some form of oil on the hood I would look for a hose leak somewhere in that region a pinhole is all it takes some times.
    Cadillac_Phx is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Concours (SOLD) / 2006 DTS Lux II
    Sep 2009
    Phoenix,AZ
    27
    63
    Does it bother anyone else that the CADILLAC CUSTOMER SERVICE member that works for the dealer always posts the same thing in every thread? "Please keep me posted on the outcome of the dealer visit. I can be reached via private message so we can further discuss the outcome and any concerns".
    I see the Dealers service dept. as dirty crooks. Over charging everything & even tampering with your vehicles (without warranty) so that you'll bring them back. My .02
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Cadillac customer service reps don't work at or for any dealer.
    And why would a copied and pasted post bother anyone? Why should they ask the same questions with different wording each time?
    Sep 2009
    Phoenix,AZ
    27
    63
    Well there is a little different wording in each but I just don't like the service people at the dealer. They loosened my ABS harness once. Luckily my cousin works for Chevy dealer and told me not to take it in. They were already telling me that it would be a $1,400 repair over the phone!! The tech at my local dealer drives a 1999 Acura, they don't care about your cars. Only the $$$
    Jul 2013
    7
    so speaking of dealers...I'm taking this to the dealer because it just seems like the way to go. should i consider an independent auto repair shop?
  16. #14
    Sep 2009
    Phoenix,AZ
    27
    63
    I got a place by me called The Cadi Shop, run by two guys who used to by Cadillac techs and went into business for them selves. Cheaper & reliable, do some research and see if any small shops near you specify in Cadillacs.
  17. #15
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by Cadillac_Phx View Post
    Hello Cadillac_Phx,
    I am sorry if you are bothered by my statements. We are here to assist our customer in anyway that we can. We ask to communicate via private message to protect customers personal information. MoistCabbage is correct, we do not work for the dealer. We represent General Motors and are based out of the Detroit headquarters. We act as a liaison between the customer and the dealer, while having the customer and fixing their issue at our best interest.
    Sincerely,
    Laura M.
  18. Remove Advertisements
