2007 DTS Lux II leak and key sticks in ignition
Results 1 to 4 of 4
Cadillac DTS Forum - 2006 through 2012 Discussion, 2007 DTS Lux II leak and key sticks in ignition in Past Cadillac Vehicle Discussion; I have a 2007 DTS that has sprung a leak with all the rain weve had in Fla its showing ...
    rickva456 is offline Cadillac Owners Member
    Automobile(s): DTS
    Jul 2013
    59
    4
    I have a 2007 DTS that has sprung a leak with all the rain weve had in Fla its showing up in the trunk passenger side and the spare tire has quite a bit of water as well it s a little damp in the back floor board so im wondering if the water could be getting to my battery, because my key kept getting stuck in the ignition and wouldnt come out so i had my dealership replace the battery which they said was the problem, the first day with the new battery no problem but the second day it stuck again after sitting a couple days it started right up and it released the key but now it will stick once in a while and i cant get it out so i carry two key fobs so i can lock the car has anyone had these problems before please help i cant afford the dealer....
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,864
    Re: 2007 DTS Lux II leak and key sticks in ignition
    Your post has nothing to do with Site Registration problems. Please read the descriptive text in each forum to find out what is supposed to be posted there. In this case, the descriptive text was in bright red.................
    Moved to the proper DTS forum.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by rickva456 View Post
    The leak in the trunk is probably the rubber seal around the edge of the trunk.
    best way to find the leak is get in the trunk with a GOOD flashlight. close the trunk and have someone spray it with a water hose.
    The key not turning all the way off may be that linkage going to your transmission is slightly out of adjustment.
    Make SURE it is in PARK all the way or the key will not come out.
    Automobile(s): DTS
    Jul 2013
    59
    4
    i also found that when on rare occasion the key does release it is hot but when i let it cool down it will come right out
  7. Remove Advertisements
