Headlight Help
Results 1 to 8 of 8
Cadillac DTS Forum - 2006 through 2012 Discussion, Headlight Help in Past Cadillac Vehicle Discussion; Hope someone can give me some help. When driving my 2006 DTS at dusk with light knob on auto the ...
    c21guy is offline Cadillac Owners Member
    Automobile(s): DTS
    Apr 2013
    7
    Headlight Help
    Hope someone can give me some help. When driving my 2006 DTS at dusk with light knob on auto the lights come on at a certain level of darkness. Right front low beam doesn't always come on. I think it has come on a time or two and and goes on and off like maybe a loose connection.
    If I turn the knob to headlights it works every time. Are there two different circuits controlling the headlights??
    Any suggestions to debug this thing?
    TIA
    Jim
    Automobile(s): DTS
    Apr 2013
    7
    Re: Headlight Help
    Has anyone had problems with a flickering/on and off headlight?
    Found some help in Search function. Several sound like my problem.
    Thanks
    phigment is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Nov 2010
    199
    Re: Headlight Help
    Its either a failing ballast or a dieing bulb. There have been a few threads on this topic. Do a search and you'll find all the information your looking for.
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    680
    Re: Headlight Help
    phigment your thread on headlight removal a while ago was great. I think you are bang on with the advice you gave c21guy, I think ballast. My parking bulb just went out. When you changed yours out, what size nut and bolt in lower cave, was it 10mm? Also can a normal depth socket go over the two bolts there? I have limited tools. Is the 2825 bulb the same as GM part #1999382? And one more question please, when you bump the bumper facia ahead 3-4 inches like you did, in no way could you unhook your parking assist sensors can you? Thanks so much for all you're help.
    BIGDADDYCADDY07 is offline Cadillac Owners Fanatic
    Automobile(s): 07 dts 1986 fleetwood brougham d'elegance
    Jun 2011
    BROCKTON MA
    136
    Re: Headlight Help
    Quote Originally Posted by c21guy View Post
    Thanks
    i had the same problem i changed my bulbs not one flicker or bulb turning off in a year now i would also change the other bulbs while you have it apart dont pay dlr price for the bulbs you can find good bulbs for 150 per pair head lamps the other bulbs are maybe 10 bucks headlight bulbs are #d1s
    fubar123 is offline Cadillac Owners Member
    Automobile(s): 06 DTS
    Jul 2013
    18
    Re: Headlight Help
    I changed both sides, no problem now. left one was flickering.
    Automobile(s): DTS
    Nov 2010
    199
    Re: Headlight Help
    Quote Originally Posted by Tom's Caddy View Post
    I used a deep socket. A shallow socket might work but I wouldn't wager a lot of money on it. I got my bulbs at autozone. I don't know what GM's part number is. If I remember correctly, the parking assist sensor(s) wiring harness is connected to the main wiring harness by a single large connector. There is slack enough as long as you do not remove the bumper completely.
    Jul 2012
    Ontario, Canada
    680
    Re: Headlight Help
    Thanks phigment. Mine is done and just a couple of hints if I may. I did not remove the wheels. You will have to do step #8 in phigments original post, the guy that said he skipped the nut in the upper cave could not have removed the lens from the car.
  11. Remove Advertisements
