2007 DTS temp gauge reading hot
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Submariner409
Cadillac DTS Forum - 2006 through 2012 Discussion, 2007 DTS temp gauge reading hot in Past Cadillac Vehicle Discussion; i have a 2007 cadillac dts and the temperture gauge keeps rising towards the red but it never actually runs ...
    bishop4lb is offline Cadillac Owners Member
    Automobile(s): 2007 cadillac dts
    Jul 2013
    1
    i have a 2007 cadillac dts and the temperture gauge keeps rising towards the red but it never actually runs hot. i have changed the radiator, thermostat twice, water pump, and temperature sensor and fan relay switch. there is no lost of fluid either. does anyone have a idea of what this could be?
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    You may have air in the system. Check the purg line is the one that goes from the coolant tank to the. Water pump area. It may be clog.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,685
    Re: 2007 dts temp gauge reading hot
    Quote Originally Posted by bishop4lb View Post
    Hello bishop4lb,
    I see you have been offered advice from grullon10. Please keep us updated on what your plan of action is and if your temperature gauge starts to work again. If you would like to further discuss your concern, please private message me and we can continue to interact.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    Gomaz's Avatar
    Gomaz is offline Cadillac Owners Fanatic
    Automobile(s): 2009 DTS II
    Jun 2010
    Canada
    164
    mine does the same thing, mine is a 09 and it goes up to almost hot, then the fan kicks in and brings it down but seems strange that it runs hot so often.
    SNIPEREAGLE177 is offline Cadillac Owners Member
    Automobile(s): 2007 CADILLAC DTS PERFORMANCE
    Feb 2013
    LOUISVILLE, KY
    30
    58
    I was told the fans kick in at 214f slow 224f fast. However the gauge is very dampened and might read improperly. I was driving with 1/16th" over the the halfway mark, no loss of coolant, and one time over the 3/4 mark straight out of the dealer. Dealer re-flashed a module not sure which one to try to compensate for the gauge reading. Its amazing how these cars work and how little it takes to run crazy. Truth is you're running a N* and these cars run hot from new, according to the GM Tech manual the transmission oil runs at an astounding 314f before the fans can be triggered to kick in and help cool it. I really hope this might help you understand a little bit about your car. If you need any diagrams hit me up and I will provide them for you. Unless you go into the limp home mode and your car maintains and average of 220f-230f of temp you're running good. To help me be at ease I installed some LEDs that tell me when fan1 and fan2 have kicked in. This definitely helped me while i was stuck in traffic and my needle moved. I dont think its right for a gauge to move but without tech2 i cant see what the temp sensor is reading and telling the computer to do. Anyways I hope this put you at ease and you could always reply if you have any questions. There are a couple of people here that were very helpful to me and they can also help.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    My temp stays mostly right in the middle... like in the picture below.
    If I am in heavy, stop and go traffic and the outside temps are over 100 the needle will move up about about one to one and a half needle width, almost but not quite, to the next mark.
    I have never seen it get all the way to the next mark.
    ChrisRick is offline Cadillac Owners Member
    Automobile(s): 2006 dts
    Jul 2013
    7
    [QUOTE=Superjim;10515913]My temp stays mostly right in the middle... like in the picture below.
    really glad you posted this pic. mine(temp gauge) is exactly like that and i've often wondered if that's where it should typically sit.
    RubirosaGGatsby is offline Cadillac Owners Member
    Automobile(s): DTS
    Jan 2013
    42
    Mine has been doing this, too, recently. To a point where it's one notch or a notch-and-a-half above the middle line. It usually only happens when I'm driving on city streets/in stop-and-go traffic; on the highway it's just fine. Wasn't sure what the right fix would be.
    grullon10's Avatar
    Dec 2012
    46
    553
    Is normal for this car to do that but also check the res cap when it goes bad it do not hold the pressure and some time it leack coolant.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,193
    You guys might want to go to the Engines, Northstar Performance threads and read the 3 cooling system sticky posts there. The 9 gauge ticks represent the same temperatures, regardless of car year/model. There are several gauge pictures, annotated with temperatures, in the Seville, Deville, and Engines; Northstar Performance threads.
    The fan controls are also pretty standard - this thread has some bad info on fan control - For the Northstar, fans run in SLOW any time an A/C function which calls for compressor operation is set. If the HVAC is OFF, the ECT sensor and PCM control fan speed: Fans go to SLOW at 224 degreesF, the engine cools to 213, fans turn OFF and the cycle begins again. (This will happen only in slow or stopped traffic - over 35 mph fans are not used/needed.) If the ambient temp is high, traffic is simply awful, or there's a cooling system fault then fans go to FAST at 236. Overheat does not occur until about 265 degrees F or so. Fans also go to FAST at a transmission fluid temp of 304 degrees - yep, 304.
    There is an annotated temp gauge in my albums - the Community tab, Albums, the red Seville. 2 albums, 6 pages of Northstar stuff.
    Don't simply skim over this picture - study it. JimD did a bunch of work on the original temperature annotation and 6 of us did more a while back. As always, YRMV.......... and, as posted, those temp numbers and ticks correspond with the gauge in the later "DTS" cars.
    tjwhite721 likes this.
  13. Remove Advertisements
