URPA or Parking Assist 07 DTS: Need diagram for sensors
Results 1 to 4 of 4
Cadillac DTS Forum - 2006 through 2012 Discussion, URPA or Parking Assist 07 DTS: Need diagram for sensors in Past Cadillac Vehicle Discussion; Hey all, I'm trying to figure out how to correct my parking assist system. I have taken it to the ...
    SNIPEREAGLE177 is offline Cadillac Owners Member
    Automobile(s): 2007 CADILLAC DTS PERFORMANCE
    Feb 2013
    LOUISVILLE, KY
    30
    58
    Hey all,
    I'm trying to figure out how to correct my parking assist system. I have taken it to the dealer and I quote "its beyond repair and obsolete now". Even though I walk 100 feet to the showroom and point out the sensors on any of the 2013 lineup. So that's the dealer I'm dealing with :/ Regardless of their poor attitude I would like to fix it. Can someone here be nice enough to share a copy of the diagram for this system and location of the URPA module?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    Re: URPA or Parking Assist 07 DTS: Need diagram for sensors
    There's a built-in diagnostic system in the URPA module. You trigger the test and use a yellow/red light flash sequence in the indicator itself to decipher the fault(s).
    Either use the GM/Helm service manual, the Cadillac Tech Tips in Discussions, or Google the AWH (Anthony W. Haukap) websites for GM diagnostics.
    Feb 2013
    LOUISVILLE, KY
    30
    58
    409, I bought a subscription to ALLDATA, excellent it gives me a full pin out of all the connectors in the car with full diagrams. However after finding the module and running voltage and resistance tests everything seems to be fine. I have 8.48 volts going to the front and rear and 430 resistance on all 8 sensors. I read an article of someone hacking these sensors and how they work. Apparently these sensors feed the module pulses in and out and can hear or create ultrasonic pulses depending on what the module tells them to do. But I did look for a test plug on mine and could not find it. Do you have a picture of what this looks like?
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    428
    No test plug on your DTS. When you had it at the dealer did they give you a list of codes. First of all whats it doing. If you can get someone with a TECH 2 to read the codes it will tell you the bad sensor or its not getting a return signal.
    DTC B0954 01 Parking Aid Front Sensor 1 (Left) Circuit—Short to Battery
    DTC B0954 06 Parking Aid Front Sensor 1 Circuit (Left)—Signal Circuit Short to Ground or Open
    DTC B0954 08 Parking Aid Front Sensor 1 (Left) Circuit—Signal Invalid
    DTC B0954 21 Parking Aid Front Sensor 1 (Left) Circuit—Incorrect Period
    DTC B0955 01 Parking Aid Front Sensor 2 (Left Middle) Circuit—Short to Battery
    DTC B0955 06 Parking Aid Front Sensor 2 (Left Middle) Circuit—Short to Ground or Open
    DTC B0955 01 Parking Aid Front Sensor 2 (Left Middle) Circuit—Signal Invalid
    DTC B0955 21 Parking Aid Front Sensor 2 (Left Middle) Circuit—Incorrect Period
    DTC B0956 01 Parking Aid Front Sensor 3 (Right Middle) Circuit—Short to Battery
    DTC B0956 06 Parking Aid Front Sensor 3 (Right Middle) Circuit—Short to Ground or Open
    DTC B0956 08 Parking Aid Front Sensor 3 (Right Middle) Circuit—Signal Invalid
    DTC B0956 21 Parking Aid Front Sensor 3 (Right Middle) Circuit—Incorrect Period
    DTC B0957 01 Parking Aid Front Sensor 4 (Right Corner) Circuit—Short to Battery
    DTC B0957 06 Parking Aid Front Sensor 4 (Right Corner) Circuit—Short to Ground or Open
    DTC B0957 08 Parking Aid Front Sensor 4 (Right Corner) Circuit—Signal Invalid
    DTC B0957 21 Parking Aid Front Sensor 4 (Right Corner) Circuit—Incorrect Period
  7. Remove Advertisements
