wheel bearing problem?
Results 1 to 5 of 5
Cadillac DTS Forum - 2006 through 2012 Discussion, wheel bearing problem? in Past Cadillac Vehicle Discussion; 2006 DTS (105,000 miles)...Car seems to be alittle louder than normal on smooth roads at 55mph...seems like sometimes i hear ...
    northstar1958 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    63
    2006 DTS (105,000 miles)...Car seems to be alittle louder than normal on smooth roads at 55mph...seems like sometimes i hear it, sometimes i don't. I checked for play...Driver side is tight, passenger side has some play...don't know if its alot or not. I have newer tie tods/struts/strut bearings installed/newer tires/alignment....maybe alittle vibration (once again its hard to tell because its so slight). Anyways...if i need to change the passenger side wheel bearing, do i need to change both? Should i be looking at something else? Thanks
    northstar
    RicktheRealtor is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III
    Aug 2004
    Calgary, Alberta, Canada
    62
    338
    Re: wheel bearing problem?
    Quote Originally Posted by northstar1958 View Post
    northstar
    You do not need to replace both at the same time, unlike some other components. However, it stands to reason that the other side will wear out sooner rather than later. But for some reason, the passenger side front wheel bearings seem to go first. ( at least in my experience).
    Nov 2008
    63
    Thanks for the info. One other question, can a wheel bearing make noise but have no play? I think i will plan on changing both bearings when i do it.
    Thanks again.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Thanks again.
    Yes.. They can make noise and still be tight with no play.
    I changed both of mine last fall after the drivers side started making noise.
    It is a fairly easy job and not real expensive.
    I also changed the brake pads on all four wheels at the same time.
    Hub and bearing assembly...Timken 513179 available on Amazon for about 100 bucks.
    Updated AC DELCO pads for the front...ACDelco 171-0985.. about 50 bucks...
    Updated AC DELCO pads for the rear... ACDelco 171-0954.. about 65 bucks...
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    What Jim said.
    And I did my wife's 2006 Performance.
    Bought the Timken hub/bearings; Raybestos PG Plus Rotors, which are high end rotors; & Akebono pads . . all from Rock Auto.
    The Axle nut is 33mm. You may need a hub puller and if you do .. rent or buy one that pulls from the studs.
    I had a problem with the left side being "frozen on" aka rust/corrosion in and around the axle splines.
    I finally got it loose by using a puller made for excavation equipment & a 3/4" CP impact wrench capable of 900 to 1000 lb. ft. of torque.
    Needless to say, I wore a face shield when removing that sucker!
    A little scary . . especially when I head a bang/pop 3 times as the impact gun was workin' hard to remove it.
    Oh, and the right side on many wears first because, that is the side that hits most of the ruts & potholes
    due to the crown of the road and where the puddles are.
  8. Remove Advertisements
