replacing cushion on driver side of a black DTS 2007 performance package also change
Results 1 to 8 of 8
Cadillac DTS Forum - 2006 through 2012 Discussion, replacing cushion on driver side of a black DTS 2007 performance package also change in Past Cadillac Vehicle Discussion; I like to know if anyone has changed a cushion on a DTS 2007 driver side seat and also has ...
    Gaf170 is offline Cadillac Owners Member
    May 2013
    Coolreplacing cushion on driver side of a black DTS 2007 performance package also change
    I like to know if anyone has changed a cushion on a DTS 2007 driver side seat and also has anyone replace the leather seat bottom half if so looking for
    some support and trying to find out if I have to do
    anything special like disconnect the battery or take
    The front seat completely out or just go ahead and
    recline the seat back and elevated as much as
    possible and strip it out and replace everything as
    needed already have parts . order from GM direct
    yeah OME PARTS GM Direct
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Re: replacing cushion on driver side of a black DTS 2007 performance package also cha
    I did this a few weeks ago. Did the seat and the back. Also replaced the seat foam. Seat cover is held to cushion with velcro. Just line it up and press it down. You will need to remove the seat from the car. No screws holding the plastic panels. Just clips. Pry the two forward seat switches off. Remove the panels by pulling straight outward away from seat. Bolts for the seat and seatbelt are Torx. Pretty big one at that. You do not have to disconnect the battery. Anymore questions please ask
    Don
    phigment is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Nov 2010
    199
    Don, was the seat foam factory or did you get it aftermarket? What was the cost of the foam? I may need to do this soon. My leather is good but my drivers seat is not what it once was.
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    As you did I bought the pieces from GMPARTSDIRECT. So the foam is factory. Made a huge difference in comfort. I think the cushion was around $45. But that was before the shipping cost which I had all 3 pieces shipped together.
    Don
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    Quote Originally Posted by Dadillac View Post
    Don
    Did you replace the leather Don ?
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Quote Originally Posted by big greg View Post
    Yes. The bottom seat cover was torn on the outside edge. So I decided to replace it. Since the back cover wouldn't be a perfect match I decided to replace that too. And the seat foam was just a what the hell. I was gonna have it all apart so figured it would be not smart to use the old one.
    Don
    Oct 2012
    32
    255
    Can you pretty please help me with the part number or Linky? I'd like to do that as well
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    http://www.gmpartsdirect.com/?CFID=1...TOKEN=36652391
    Top right click catalog. Put in your info. Click body hardware, then seats & tracks, then front seat components. Rest is obvious from there. There are schematics so you find the correct part. Just make sure you read the entire description as there are several different options for the same part.
    Don
    Quote Originally Posted by phigment View Post
    Part number 25944059. This is with seat heater which almost all DTS's have. 15216256 if you do not have the seat heater.
    Don
  11. Remove Advertisements
