Transmission service
Results 1 to 4 of 4
Cadillac DTS Forum - 2006 through 2012 Discussion, Transmission service in Past Cadillac Vehicle Discussion; Hello everybody. My DTS is a 2006 model with 80k miles on the clock. I'm currently catching up on some ...
    Baccerman is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Jun 2013
    18
    Hello everybody.
    My DTS is a 2006 model with 80k miles on the clock. I'm currently catching up on some long needed maintenance. So far I've replaced a noisy wheel bearing on the right front axle, replaced the dex-cool in addition to the usual 5k oil change (mobil 1)
    Question:
    I'm getting ready to service the transmission and I'm curious about the BG flush service offered by the local dealer. I've been told by a trusted mechanic friend that the flush is probably not a good idea at this mileage.(fluid is original, still looks and smells ok).
    He says to drop the pan and clean or replace the filters and replace the fluid, although all of the fluid will not be changed.
    Any opinions?
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    Re: Transmission service
    Keep trusting your friend. Flush is not necessary, and if done improperly, can cause problems. Drop and clean the pan. Be sure to remove the drain plug for the side reservoir that's inside the transmission. That's where most of the fluid is at. Do a search on the site. I believe there was a recent post with a picture of this plug. You'll probably get 60-70% of the fluid out. That's enough. Be sure to use only Dexron VI.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Jun 2013
    18
    Thanks for the reply. Does anyone have a picture of the drain plug inside of the transmission?
    Thanks... I found it with the search feature. Im new to forum... this is GREAT!!!
  7. Remove Advertisements
