2007 DTS, accelerating on right turn causing vibration?
Results 1 to 6 of 6
Cadillac DTS Forum - 2006 through 2012 Discussion, 2007 DTS, accelerating on right turn causing vibration? in Past Cadillac Vehicle Discussion; 2007 DTS accelerating on right turn causing a vibration, shudder, seems to be coming from right passenger side front. Any ...
    Deltat210 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac DTS
    Feb 2013
    5
    2007 DTS accelerating on right turn causing a vibration, shudder, seems to be coming from right passenger side front. Any input? Also have the infamous vibration in the gas pedal going over a bump.... thanks in advance guys! Oh, 60,000 miles on the car....
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    check for a bent ream. It happen alot
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    Re: 2007 DTS, accelerating on right turn causing vibration?
    What is a ream?
    Could be a bad wheel hub.
  5. #4
    grullon10's Avatar
    Dec 2012
    46
    553
    You may have a bad Rim or you need a wheel balance does the car do it at high speed.
    Also check that side strut .
  6. #5
    Feb 2013
    5
    It does do it at high speed, only during acceleration, kind of a grinding. Wouldnt a bent rim or balance do it all the time at highway speeds?
  7. #6
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by Deltat210 View Post
    Wouldn't a bent rim or balance do it all the time at highway speeds?
    Yes...
    See if you can find a safe place and try this....
    Get up to 35 or 40 and then turn the wheel back and forth (left then right then back left)... like they do in NASCAR...
    This will cause more weight to be applied to each front wheel as you go back and forth.
    If it is a bad hub bearing... you will notice the noise increase on the bad side when you do this.
    Jim
  8. Remove Advertisements
