What are the best Spark Plugs
Results 1 to 10 of 10
Like Tree1Likes
  • 2 Post By MoistCabbage
Cadillac DTS Forum - 2006 through 2012 Discussion, What are the best Spark Plugs in Past Cadillac Vehicle Discussion; I want to change my spark plugs, and want to know what are the best ones on the market? I ...
    Rocc4Rocc is offline Cadillac Owners Member
    Automobile(s): 02 Cadillac Deville, 03 Cadillac STS, 07 Cadillac DTS
    Apr 2013
    28
    I want to change my spark plugs, and want to know what are the best ones on the market? I would like to boost my MPG if possible.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Use ONLY the correct AC Delco plugs, Northstars tend to foul most others.
    You're not going to get any more MPG or performance out of a plug change.
    Superjim and Superjim like this.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: What are the best Spark Plugs
    ^^^^^^... What Moist Cabbage said...
    Use AC Delco 41-987
    RicktheRealtor is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III
    Aug 2004
    Calgary, Alberta, Canada
    62
    338
    I've posted this before, but, again, I was very surprised that when I finally changed the plugs on my N*, the original, factory installed plugs were NKGs. (sorry, forget the number). I would suspect that in daily driving, one would be hard pressed to actually measure any mileage difference between brands. Those AC Delcos are probably made in China today, anyways.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by RicktheRealtor View Post
    Just bought a set of 41-987's the other day...
    They are actually made in Japan... LOL
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the acdelcos are most assuredly rebranded from another spark plug brand but who knows what they are exactly ... best to just stick with the delco's
    they're not super expensive anyway
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,590
    My money is on rebranded DENSO plugs - The original plugs in a lot of the late 90's - early 2000 Northstars were DENSO (My 2002 had them in it) the Cadillac Seville owner's manual uses a cross-referenced DENSO p/n (PT16EPR-C13), and the new AC Delco #41-987 is "Made in Japan", probably by DENSO.
    Which car does the OP want to change plugs in ??? Does the 2007 Northstar still use #41-987 ?
    If you believe the hype that cutesy spark plugs will give you increased gas mileage, I have a bridge to Brooklyn that I'll sell, cheap. If your existing spark plugs are over 100,000 miles old and are filthy and the electrodes are eaten away, then ANY new plug will give you some performance increase (you'll never notice it) - but by and large, the original double platinum AC Delco plugs are the best to use.
    I seriously doubt the original plugs were NGK. DENSO, maybe. Today's AC Delco plugs (for the Northstar series, anyway) are boxed "Made in Japan".
    Sep 2007
    Wilmington, NC
    13,986
    yes Sub, the 2006-2011 DTS uses 41-987 plugs (for both the 9 & Y engines)
    Feb 2006
    55,590
    Not too shabby - 12 model years of engine using the same plug - the things should be around for a while ...........
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    The 07+ STS does too
    The 05-06 calls for 41-986 no clue why they changed the gap. I swapped mine out for 987s and closed the gap to set them for the 986 gap.
  13. Remove Advertisements
