Service Brake System
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By TK76
Cadillac DTS Forum - 2006 through 2012 Discussion, Service Brake System in Past Cadillac Vehicle Discussion; 06 DTS. Service Brake System light comes on every week or two. Resets by cycling the ignition switch. New pads ...
    Ozlander is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Mar 2011
    Rose Hill, Kansas
    131
    New pads on the front a month ago, rear have 1/8 inch left.
    How do you find the cause?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Service Brake System
    The first thing I would do is check the brake fluid level... assuming you have not already did that.
    The next thing I would do is... Assuming you have OnStar.... When the light comes on again, push the OnStar button and they can tell you the exact code that is set.
    Post the code here and we will try to help.
    Mar 2011
    Rose Hill, Kansas
    131
    Thanks Jim, I didn't know OnStar could do that. Or I kind of did, but didn't think about using them for that.
  5. #4
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,666
    Ozlander,
    I checked the 2006 DTS manual and see that SERVICE BRAKE SYSTEM will display if your vehicle is low on brake fluid (p.3-84). Have you checked into this possibility already?
    Sarah, Cadillac Customer Care
  6. #5
    Mar 2011
    Rose Hill, Kansas
    131
    Quote Originally Posted by Cadillac Cust Svc View Post
    Ozlander,
    The message hasn't returned. The brake fluid level is at the seam which is 3/8" above the 'MIN' mark.
    Ozlander
  7. #6
    Mar 2010
    Detroit, USA
    12,666
    Quote Originally Posted by Ozlander View Post
    Ozlander
    Hello Ozlander,
    Glad to hear of this update and to know that your brake fluid level is full and properly running.
    Regards,
    Laura M.
  8. #7
    TK76 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac DTS
    Oct 2014
    1
    I suddenly started to get multiple SERVICE CODES (Service Brake System, Service Brake Assist, Service Stabilitrak, Service Traction Control, BRAKE LIGHT etc) and thanks to these forums, I found a half dozen possible answers.
    LOW BRAKE FLUID seemed to be the simplest place to start. I found my fluid level low - added fluid to the right level - pumped the brakes hard while sitting in PARK in our driveway with the engine running. I moved the car and sure enough there was brake fluid on the ground where one of the wheels had been. Slowly and carefully, I drove the car to my trusted local mechanic - told him which wheel to check. That was the source of the problem. My mechanic fixed the leak - bled and refilled the system. All SERVICE CODES are now gone and brakes seem back to normal. TOTAL COST $53.
    Superjim likes this.
  9. Remove Advertisements
