Weird problem - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 87 of 87
Like Tree4Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, Weird problem in Past Cadillac Vehicle Discussion; D on, You mentioned in Post #64 that you “ went to the dealer today. They said they scanned it ...
  1. #76
    jazoo is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Jun 2012
    366
    Re: Weird problem
    Don, You mentioned in Post #64 that you went to the dealer today. They said they scanned it and found nothing that would cause this problem. Then in Post #71, you said well I think we got somewhere today. They did more diagnostics and hooked it up to the machine……... So is this continuation of Post #64 or is this a different dealership? I hope you got it fixed finally.
    Don, couple of questions; 1) did your scanner or on-board diagnostics (OBD II) computer pull any codes at all?, 2) Shouldn’t you be looking @ replacing all eight coils instead of just two (I don’t remember that you mentioned the odometer readings on your vehicle)?
  2. #77
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Weird problem
    First diagnosis was with the Tech2 scanner. There was no fault codes using the Tech2. So they went to general diagnostics and started with fuel pressure. After that there was some other machine that I guess graphs ignition. Don't ask me what it is because I haven't seen it. But the tech said it was graphing all crazy with a misfire. So that's when he changed the coil and it quieted the graph down. My car has 65,000 miles on it and I am not yet ready to replace 8 coils at $50 a pop just yet. If they were half that I would do it. Also my scanner showed no codes. It only reads emission codes that would trip the CEL. And the CEL never came on so my scanner said all things were good. Oh and it was the same dealer.
    Don
  3. #78
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Weird problem
    I have a little over 130,000 on mine and I guess I have been lucky.
    Except for a half case leak that was fixed under warranty it has been pretty much trouble free.
    Other than that, it has never had a wrench on the engine or transmission.
    No ignition problems or fuel problems ... at least not yet.
    It still has the original plugs in it... I probably need to change them...
    Jim
  5. #79
    RicktheRealtor is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III
    Aug 2004
    Calgary, Alberta, Canada
    62
    338
    Re: Weird problem
    Quote Originally Posted by Superjim View Post
    Jim
    I bet your plugs aren't carbon fouled!
    Superjim likes this.
  6. #80
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Weird problem
    New coils arrived today and I got them installed. So far so good. I will know in the morning if the issue is 100% gone or not. I am positive it is
    Don
    ronm01 likes this.
  7. #81
    BIGDADDYCADDY07 is offline Cadillac Owners Fanatic
    Automobile(s): 07 dts 1986 fleetwood brougham d'elegance
    Jun 2011
    BROCKTON MA
    136
    Re: Weird problem
    the misfire you had on a scale of 1 to 10 what would you describe it was and was it noticeable when at normal temp???
  8. #82
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Weird problem
    It varied in intensity. The major symptom was a feeling of the car wanting to drive while my foot was on the brake. Quick misfires in rapid succession. When the engine was fully up to temperature the frequency and intensity died down significantly.
    I drovebto work this morning to a butter smooth engine. Issue is completely gone.
    Don
  9. #83
    Jun 2011
    BROCKTON MA
    136
    Re: Weird problem
    nice that what we like to hear enjoy the ride brother
  10. #84
    Jun 2012
    366
    Re: Weird problem
    Quote Originally Posted by Dadillac View Post
    Don
    Congrats!!! Don, I'm so happy for you. Your hard work (& perseverance) is finally paid off.
  11. #85
    HASSAN4477 is offline Cadillac Owners Member
    Automobile(s): 06 DTS PERFORMANCE
    Oct 2012
    43
    Have ur cats checked out or the resonator this could explain y no codes its after all the extra sensitive stuff. Did you clean you're manifold on the inside I foind alot of carbon in mine also try sea foam to clean the carbon from the cylinders
  12. #86
    Aug 2004
    62
    338
    Re: Weird problem
    Don
    Nice to hear. Congrats. BTW, Happy Fourth to all my American friends.
  13. #87
    TulsaVic is online now Cadillac Owners Enthusiast
    Automobile(s): '08 DTS Performance (gone); '11 Jeep Grand Cherokee Summit; 2017 MB C300 Cabriolet
    Jan 2008
    Harrison, ME
    70
    824
    Re: Weird problem
    Jim
    Guess this is testament to the belief that the N* was built to be driven hard ....
  14. Remove Advertisements
