Replace with KYB Shocks ?
9K views 16 replies 8 participants last post by  stormnn
I am to replace the shocks on my DTS 06 with KYB air shocks:
http://www.ebay.com/itm/KYB-SR1002-Rear-Shock-Absorber-/310444853954?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ADTS&hash=item4847f48ac2&vxp=mtr
I found them cheeper and I know they have decent reputation. They perfectly fit the DTS as I checked the KYB Catalog :
http://showmetheparts.com/kyb/
The catalog provides the following part description:
Reae Shock Absorber: (Exc. Electronic Susp.); w/ FE1 (Soft Ride Suspension) (Exc. Limo, Hearse, Armoured Body); Box contains two Air Shocks; Recommended OE Replacement
I am not quite sure of what Exc. Electronic Suspension means. And my bigger concern is whether I will face problems of any kind if I install them? Coz these are "air-shocks" and seem to be less high-tech.
Thanks
Idris
#2 ·
The electronic ride is what people call sport suspencion it is very easy to find out if you have the electronic instead of the regular take a look at the top of the rear shock or the struck if a they have a electric plug coming out of it them. You have electronic ride not the air line connection a electrical one.
#8 ·
MoistCabbage is talking to hisself.
Appears there's been some fermentation.
Your handling will be sloppier with the back end moving more. Is it a question of money, or do you want a softer riding car?
I believe you can replace the MRC shocks one at a time, instead of in pairs as with normal shocks.
#9 ·
I was questioning my original answer.
He'll still have the stiffer FE3 springs. Ride will be very similar unless he drives very aggressively.
Incorrect.
#11 · (Edited)
Why else would he buy a Performance model {which he should have told us in the original post}? (but perhaps he didn't choose it).
I thought I read here that the springs rates were the same for all non-commercial DTSs. Will he want firmer springs with softer shocks, or is it only a small difference?
I assume that automatic level control works independently from the MRC.
#10 ·
Actually, can the MRC option be disabled with a Tech II in the '06+ cars?
No
Its on the High Speed Lan. The ECM,TCM,BCM will be looking for its ID code. If the BCM doesn’t recive the code {ID} of the MRRTD it will tell the ECM to have the IPC display MAXIMUM SPEED 80mph.
You can put in Base struts and us resistors to keep it from setting codes.
#12 ·
Resistors can be used in the older F45 (CVRSS), but not the F55 (MagnaRide) cars. You sure you can use resistors for the '06+ MRC cars? What value?
Most people who drive performance models (of any car), don't use them to their full potential. I highly doubt he's driving the car close to its handling limits.
FE3 includes different dampers, springs, and sway bars.
Not a big enough difference to have to worry about swapping springs.
Correct.
#13 ·
My base DeVille would hold the road better than the seat would hold me, but the DTS will take turns confidently at speeds I would not have dared with it. I hope the OP won't learn the hard way that there is a difference.
