Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Replace with KYB Shocks ?
  1. #16
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Replace with KYB Shocks ?
    Quote Originally Posted by ltdltc View Post
    That may be on older K Bodies. On 2006+ DTS the coil springs # rate are exactly the same front and rear on a VIN 9 or VIN Y DTS. The only difference is that on VIN 9 cars the rear coil springs are a 1" to " taller to accommodate the MRC shocks.
    Before trading in my Lux II I looked at getting the coil springs from a Performance sedan but then found out they are the same. When I swapped out the AC Delcos for Monroes the car rode a whole lot better. But MRC is really a lot better but even with MRC I find the car still float a bit. Par for the course I guess.
    If you haven't tried it already... run 36 psi cold in the front tires and 34 psi cold in the rear tires.
    The higher pressure pretty well eliminates the float on mine on the highway.
  2. #17
    stormnn's Avatar
    stormnn is offline Cadillac Owners Fanatic
    Automobile(s): 06 Cadillac DTS
    Sep 2008
    Bowmanville Ont. Leesburg Fl.
    73
    278
    Quote Originally Posted by Superjim View Post
    What he said & especially if the car is loaded. Even 36 rear if loaded.
    Norm
  • You may not post replies
