Results 1 to 10 of 10
Thread: Lets see those aftermarket wheels
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Cleaned up my wheels on Sunday. Took each wheel off of the car to clean them thoroughly. Faces look good but the barrels are trashed. Three out of the four have major chrome peel. The other one has the early stage. It won't be long before the peeling spreads and the faces get affected. I priced new wheels and they are out of my price range. So aftermarket is my only option. Keep in mind that I will not be changing anything until the peeling hits the face of the wheels. So hopefully that won't be for a very long time. I contemplated getting my wheels re-chromed but that will be almost as expensive as buying new ones and I will have to get a spare set of wheels and tires while that gets done. So that option is out. Not gonna be happy about aftermarkets but I am gonna have to live with it. Unless someone can point me to a set of 18" performance chromes that will go for less than $1k. So anyway to anyone who has aftermarket wheels lets see them. Definitely going to need some ideas on what will look good on the car
    Don
    RubirosaGGatsby is offline Cadillac Owners Member
    Automobile(s): DTS
    Jan 2013
    42
    Re: Lets see those aftermarket wheels
    Craigslist will probably be your friend in this search. I found my set of wheels, discontinued MC2's from a Dodge Magnum in virtually flawless condition, on Craigslist... for $200. The key is patience. I was looking for about two months before I finally found the best bargain on what I was looking for.
    Also, depending on where it's peeling, you may be able to get away (and look good/unique) with painting/powder-coating them.
    Eninety2 is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville
    Jun 2011
    37
    134
    Dodge has the same bolt pattern?
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes. 5X115.
    But... If buying used, after market rims. Make sure they're actually 5X115, and not 5X114.3. NOT "close enough".
  6. #5
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    Yes. 5X115.
    Why not? That's what my 22s are right now. I'm just curious to why you say no.
  7. #6
    Sep 2010
    East Boston MA.
    29
    26,323
    Because they're the wrong size.
    114.3 is smaller than 115. When you bolt the rim on, all of the hardened (fairly brittle) studs are being bent inwards. The outer edges of the tapered lug seats are also being galled every time the lug nuts are turned.
  8. #7
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    What exactly does the 115 measure? The diameter of the circle through the lug centers?
    At least in photographs, I think the 06-09 Performance wheels are the best looking of any I've seen on a DTS, including my own, and I don't usually like chrome wheels. The simple design looks good with the clean lines of the car.
  9. #8
    Oct 2012
    32
    255
    .7 mm I close enough for me. I think every shop around here does it. I use centric rings as well. And the lugs barely move .35 mm a piece. But technically they are wrong.
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,323
    Good enough for you, does not make it ok or safe. If you're going to recommend installing ill fitting parts, with potentially damaging/dangerous results, on a public forum, include a disclaimer.
  11. #10
    Oct 2012
    32
    255
    Everything I do has a disclaimer. Lol.
  • You may not post replies
