Tighten Oil Pan
Results 1 to 5 of 5
Cadillac DTS Forum - 2006 through 2012 Discussion, Tighten Oil Pan in Past Cadillac Vehicle Discussion; I hope someone has the info I need. The oil pan has 10mm bolts heads, I can tighten most of ...
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    681
    SmileTighten Oil Pan
    I hope someone has the info I need. The oil pan has 10mm bolts heads, I can tighten most of them but 2 have no room for my extension bar. The problem is the thickness of the extension bar. Is there such a thing as a very thin extension bar for this kind of work that I could put the 10mm socket on the head and then slip through a very thin shaft extension bar that would be able to connect to the socket. I buy tools as I need them so if this sounds stupid its because I have basic socket sets at home. Any help would be great thanks.
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    Re: Tighten Oil Pan
    Do you have a 1/4" socket set? My 1/4" extensions are about half the diameter of my 3/8".
    Jul 2012
    Ontario, Canada
    681
    Re: Tighten Oil Pan
    No I thought mine were 1/2 but maybe 3/8 I'm at work I will check when I get home, but the clearance is only the thickness of a small green Roberts screw driver shaft, would 1/4 be thin enough? Thanks for the reply.
    billdaman is offline Cadillac Owners Fanatic
    Oct 2010
    NeW York
    226
    Re: Tighten Oil Pan
    Quote Originally Posted by Tom's Caddy View Post
    I hope someone has the info I need. The oil pan has 10mm bolts heads, I can tighten most of them .
    Be sure not to over torque those Oil pan bolts!
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    Quote Originally Posted by billdaman View Post
    No impact needed!
  8. Remove Advertisements
