Results 1 to 6 of 6
Thread: Alignment
    CaddyMAK is offline Cadillac Owners Fanatic
    Automobile(s): DTS 2006
    Nov 2011
    198
    Alignment
    I was told that there are two kinds of alignment specs: (1) within intolerance and (2) factory recommended. I am assuming that the factory are specific. Is this the case? What are the exact factory specs regarding alignment on our car? Thanks!
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    Re: Alignment
    The FSM will give a preferred setting for each angle, toe, camber and caster, and then a range, usually about one degree either way, that is acceptable. A good tech will set to the preferred spec. Some will just get it in the range and let it go. Some places charge for a full alignment and give a half-ass check of the toe and run you out the door.
    A car that is in the "acceptable range" can still have problems. If caster is +1 degree on one side and -1 degree on the other, you can have a very slight pull that is hard to fix if you keep taking it to the same lazy shop.
    A really good tech will know what works and doesn't work on different cars. First time I took my El Camino to my front end guy, he asked if I wanted to throw in a couple of degrees of extra caster to make it track better. That was almost twenty years ago. I'm just afraid he's going to retire soon.
    Nov 2011
    198
    Re: Alignment
    Thanks for the info, tightwad. I have the PDF manual I got off of ebay, which one of the guys on this forum suggested to all. I could not find the preferred settings. I'm bringing her back in tomorrow morning to the same place I bought my new tires (about 1-2 months ago). They forgot to reset the TPMS and I asked the manager about the alignment. He said they would set it to the factory settings. Hopefully that was a true statement. Right now she's within allegedly specs:
    Front Camber: L 0.0 R 0.1
    Front Caster: L 5.5 R 5.3
    Front Toe: L 0.10 R 0.10
    Rear camber: L -0.2 R -0.4
    Rear toe: L 0.05 R 0.03
  5. #4
    danog is online now Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    443
    Re: Alignment
    This bulletin is being issued to revise the Wheel Alignment Specifications in the Wheel
    Alignment sub-section of the Service Manual. Please replace the current information in
    the Service Manual with the following information.
    The following information has been updated within SI. If you are using a paper version
    of this Service Manual, please make a reference to this bulletin on the affected page.
    Suspension
    fE1,FE3,FE7
    Front Camber -0.00° ±0.75
    Front Camber Cross Tolerance ±0.75°
    Front Caster 5.80° ±0.75
    Front Caster Cross Tolerance ±0.75°
    Front Total Toe 0.20° ±0.20°
    Steering wheel Angle 0.00° ±3.50°
    Thrust Angle --
    Rear Camber -0.05°±0.75°
    Rear Total Toe 0.10° ±0.20°
    Rear Thrust Angle 0.00° ±0.20°
  6. #5
    Nov 2011
    443
    Re: Alignment
    °oo
    jj
  7. #6
    baxnt is offline Cadillac Owners Member
    Automobile(s): 2014 Escalade Platnum
    Aug 2016
    Jefferson City, Mo
    68
    1
    Re: Alignment
    Thanks for this info
  • You may not post replies
