Timeserts?
Results 1 to 7 of 7
Cadillac DTS Forum - 2006 through 2012 Discussion, Timeserts? in Past Cadillac Vehicle Discussion; 06 DTS 4.6 Y engine code getting exhaust gasses in coolant and overheating. Mech says it needs timeserts in the ...
    Ollie01 is offline Cadillac Owners Member
    Apr 2013
    1
    Timeserts?
    06 DTS 4.6 Y engine code getting exhaust gasses in coolant and overheating. Mech says it needs timeserts in the block when replacing the head gaskets? I found info for the older model engines, but not the 2006? Does it need all this extea work?
    Thanks for any info.
    stormnn's Avatar
    stormnn is offline Cadillac Owners Fanatic
    Automobile(s): 06 Cadillac DTS
    Sep 2008
    Bowmanville Ont. Leesburg Fl.
    73
    278
    Re: Timeserts?
    Very rare for head gaskets to go since the update in the 04 model year. If that is your problem it's the 1st. I've heard about.
    Cost my buddy $5000 to do his mint 2000 4.6.
    Norm.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    When HG issues occur in an engine with course head bolt threads (some '04's, all '05+), it's a legitimate gasket issue, not a bolt hole thread pulling issue. No machine work/inserts should be necessary, just new head bolts (which are one time use, torque to yield).
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    544
    Re: Timeserts?
    Back when 'The Guru" used to post on here, he stated that timeserts were developed to use not only if the threads failed, but also due to the fact that removing and reinstalling the headbolts may damage the threads. Even with the newer coarse threads, I'm not sure if I would risk all that work and still have another problem later on.
    Sep 2010
    East Boston MA.
    29
    26,325
    That's true, inserts used to be part of the repair weather there was thread damage or not. But the corse threads are more robust than the fine threads of the older engines. AFAIK, no thread repair is done at a dealer service department after head removal on the newer, corse thread blocks.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Timeserts?
    no timeserts used on the coarse thread blocks
    usually the gasket failed or some of the bolts weren't perfectly torqued and allowed the gasket to fail
    same job as before just no tapping or inserting the block
    bigtone's Avatar
    Jun 2003
    544
    Re: Timeserts?
    Thanks, good to know.
  10. Remove Advertisements
