Washer Fluid Low indicator on and reservoir is full
Results 1 to 2 of 2
Cadillac DTS Forum - 2006 through 2012 Discussion, Washer Fluid Low indicator on and reservoir is full in Past Cadillac Vehicle Discussion; DIC shows washer fluid low but the reservoir is full. I ran a small amount out thinking I overfilled it. ...
    frostsdad is offline Cadillac Owners Member
    Oct 2005
    16
    DIC shows washer fluid low but the reservoir is full. I ran a small amount out thinking I overfilled it. Didn't work either. I clear it on the DIC and it comes back after a short time.
    Does this sound like just a bad sensor?
    It's under warranty so I plan I have the dealer check it out.
    Curious if anyone has had a similar issue. Annoying because it blocks other info in the DIC unless u continually reset it.
    cjcarlin is offline Cadillac Owners Member
    Automobile(s): 08 DTS 1SE
    Jul 2011
    Muggy S.E. Louisiana
    58
    39
    Re: Washer Fluid Low indicator on and reservoir is full
    I had the same problem with my '08. They replaced the sensor after playing around with it for a while. No problems with it since.
