DTS Electrical problems
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree2Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, DTS Electrical problems in Past Cadillac Vehicle Discussion; My battery runs down mysteriously while the car sits idle for several days. Anyone know of electrical problems with the ...
    schneijohn is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Jun 2012
    1
    My battery runs down mysteriously while the car sits idle for several days. Anyone know of electrical problems with the 2006 DTS?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Is the battery original?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: DTS Electrical problems
    DO NOT leave anything plugged into any of the outlets if you are going to be away from the car for more than a couple of days.
    I am talking about cell phone chargers, radar detectors or anything else that plugs into the 12V outlets.
    Mr.electric is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2013
    80
    Not worth the money to find that issue on a luxury car. Just put a little solar battery tender on the dash or a plug in battery tender and be done with it. You surely need a new battery too.
    Sep 2010
    East Boston MA.
    29
    26,323
    So if there is an electrical problem, you're suggesting ignoring it?
    Mar 2013
    80
    Well I'm an auto mechanic by trade and yes I'm suggesting to ignore it. Simply because it is in the minor inconvenience category and extremely expensive category at the same time.
    If his iPhone charger and other peripherals are not the cause then it is most likely something expensive like a computer.
    If he really wanted to fix it then he could do this:
    First get a new battery and see if the problem persists if it does
    Disconnect the battery negative terminal
    Connect a test light between the battery negative terminal and battery cable, now all current out of the battery must pass through the bulb in the test light first.
    Leave the ignition off
    The test light will probably slowly pulse on and off. This is the an indication of the parasitic loss. The light should be very dim and could pulse if everything is normal. If you have the opportunity try this on a known good similar model car first to compare with your car.
    On your car the light bulb should illuminate more brightly if there is an unusual constant drain
    Now pull one fuse at a time while observing the bulb. Any fuse that makes the bulb significantly dimmer is the one that indicates the trouble area / circuit. Keep in mind the bulb will never go out completely unless you pull the main fuse.
    Another tip, the draw may automatically drop after the car has been sitting for about five minutes.
    Another tip do the test with all the doors closed , so close the door jam switch somehow.
    brucehammond is offline Cadillac Owners Member
    Automobile(s): 2006 DTS, 2013 ATS 2.5
    Nov 2012
    57
    60
    I had what I thought was a parasitic draw that turned out to be a bad battery. It was only 10 months old. Get a new battery first.
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by Mr.electric
    ...First get a new battery and see if the problem persists...
    Quote Originally Posted by brucehammond
    ...Get a new battery first....
    Or, he could have the battery TESTED first, instead of guessing and throwing money at it.
    Gomaz and Gomaz like this.
    Mar 2013
    80
    Good point. Load test the battery.
    Nov 2012
    57
    60
    They tested the battery twice and said it was good. I insisted they change the battery and it solved the problem. Load testing doesn't always work as I found out.
    Mar 2013
    80
    Weird. Maybe your car has a parasitic drain.
    I think the term for an bad computer that draws power when off is " fused logic gate" anyways you can expect to spend at least a grand on the part alone.
    FYI Those solar cells that you leave on the dash are only $25
    Sometimes you have to make a change to your cigarette lighter wiring so that it stays on when the car is off allowing the battery to charge from the solar cell with key off.
    For cars that are stored indoors I have permanently installed small battery tenders. Classic cars that are driven very infrequently always need some help in the battery department. I like to hide the ac plug for the charger somewhere in the grill or under the bumper like a block heater cord. The car stays plugged in when out of use for months at a time them has a full charge when the time comes to try to start it again.
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    443
    Parasitic Draw Tests with a test lamp went away in the 90ís
    With newer cars you canít use a test light. Most GM cars from 2000 and up can draw 20 to 30 mA after all computers have gone to sleep will be normal.
    You canít tell that with a test lamp. With an AMP meter you would know its normal.
    Important:Removing fuses, relays, and connectors to determine the failure area may wake up modules.
    You must wait for these modules to go to sleep or use the sleep function on the scan tool
    ON star will draw 20 ma for 48 hours
    All Gen 6, 7, 8, and 9 systems are powered up continuously for 48 hours from ignition off. After the 48 hours the Gen 6 and
    some Gen 7 power off; Gen 7.XXL, and all Gen 8 systems will enter a 9 minute OFF 1 minute ON power cycle for an additional 72 hours.
    Gen9 and FCP1 (Volt) will remain in that mode for 120 hours (5 days). At the beginning and end of the 1 minute ON stage,
    you may experience a short spike of current at the beginning and at the end. This allows for calls from OnStar to be received by the system.
    The graph below indicates roughly how many days a 690 CCA battery with at 110 min. RC (60.5 AH) starting at 80 percent state of charge will last with a constant current draw until it reaches 50 percent state of charge. Differences in battery rating and temperature will affect the results.
    -Current Drain Days
    25mA ------ 30.5
    50mA ------ 16.5
    75mA ------ 11
    100Ma ------ 8.25
    250mA ----- 3.3
    500mA----- 1.65
    750mA ----- 1
    1A --------- 0.8
    2A --------- 0.4
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    My DeVille mysteriously drained overnight once or twice when it was really warm and humid out. I don't think it did it after the battery was replaced some months later.
    It sounds like the Nav DVD loader is running multiple times after I open the door to get in my DTS. I assume that's normal. I've no idea if the DVD is inside--no use for it at the moment.
  16. #14
    Mar 2013
    80
    Quote Originally Posted by danog View Post
    -Current Drain Days
    25mA ------ 30.5
    50mA ------ 16.5
    75mA ------ 11
    100Ma ------ 8.25
    250mA ----- 3.3
    500mA----- 1.65
    750mA ----- 1
    1A --------- 0.8
    2A --------- 0.4
    Good chart. I think using a test light is still here. At least the master techs at the dealership I worked at used them. The light is just a short cut. Using an ammeter is more accurate. The thinking to keep in mind is there is no one correct way to fix a car. The point is getting it done, hopefully in a relatively short period of time. Otherwise the customer is overcharged. Example spending an extra 45 minutes jotting down ammeter readings and comparing to a chart when 9/10 times it is either the cell phone charger or a bad battery that causes such problems. If it is not the usual problems the tendency for the computers to sleep and wake up makes it very difficult to find the issue. Using the scanner to enable sleep mode sounds like a really good technique. Every heard stories of cars that have been to numerous shops to have a parasitic drain fixed ? It is not an easy problem to address. The shop that satisfies the customer wins. Which may include various solutions. Billing for a few hours labor and a $1000 computer only to have the customer come back with the same complaint is not one of the ways to satisfy the customer.
  17. #15
    Atavar is offline Cadillac Owners Fanatic
    Aug 2013
    ND
    61
    211
    It must be a fairly good drain to run the battery in a DTS down in two days. As a smoker I have an ionizing air filter with a fan plugged in and powered up 24x7 and it hasn't run the battery down noticeably yet.
    BTW, an ionizing filter makes a *huge* difference in the freshness of the interior, especially if like me you occasionally smoke while driving. This is the one I use
    http://www.sharp.ca/en-CA/ForHome/Ho...s/IGBC2UB.aspx
    It draws about 3W on high which is about 250 ma. By the chart above that would be 3 days to pull the battery down to 80%. I can live with that.
  18. Remove Advertisements
