whitewall tires on a 2009 dts
Results 1 to 10 of 10
Cadillac DTS Forum - 2006 through 2012 Discussion, whitewall tires on a 2009 dts in Past Cadillac Vehicle Discussion; I have been looking for whitewall thin stripe tires for my 09 dts. I cant seem to find anything but ...
    bigdee4444 is offline Cadillac Owners Member
    Automobile(s): 07 escalade ext 09 dts
    Jul 2012
    33
    6
    I have been looking for whitewall thin stripe tires for my 09 dts. I cant seem to find anything but vogues that match the 235 55 17.(are they any good comparable to the stock tires). I have seen other sizes like 235 60 17 but not sure if they would fit, handle or even look good. thanks i really appreciate any help.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: whitewall tires on a 2009 dts
    the only whitewall tires i could find in that size are Goodyears the Eagle LS and the Radial LS
    both on the more expensive side of the list of tires in that size
    i've also got a call into my TireRack rep to see if they have anything
    just got off the phone with TireRack
    they only have those two Goodyears
    they're more expensive because of their load rating (they're livery/limo tires)
    CadillacVogue is offline Cadillac Owners Member
    Automobile(s): 06 Cadillac DTS Performance
    Feb 2013
    Minnesota
    28
    26
    If your looking into the Vogues, they are pretty decent tires. For the price you could probably find something a bit better, but one thing to keep in mind is their roadside warranty. Basically if you have a tire go bad for any reason and you are still within a certain tread depth Vogue will sell you a new tire at a considerable discount.
    About a year ago I found a large slice in my tire; apparently I drove over something at some point, and I brought the tire into Discount Tire to see if they could get me a new one. They called Vogue; measured the tread depth and Vogue instructed them to sell me a new tire at a 50% discount. I had a little over 10,000 miles on the tire at that point. Just for that they are well worth the premium.
    The only negative I can think of with the whitewall Vogues is keeping them clean. Its a huge pain, especially during the winter months.
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    The link below will tell you how far off a different size tire would be:
    http://www.miata.net/garage/tirecalc.html
    I would think someone would be making whitewall tires for "classic" cars, but probably not in R17. There really isn't enough sidewall left on newer cars to make a stripe worth the trouble. Someone posted their Vogue rubberbands on the Show us your ride thread today. I suppose it's one way to show off your disposable income--$1000s in wheels and tires on a 5 y.o. car.
    HartfordGuy's Avatar
    HartfordGuy is offline Cadillac Owners Enthusiast
    Automobile(s): 1968 Eldorado
    Oct 2009
    Hartford, CT
    50
    785
    There have been a couple of lengthy threads here on this issue with lots of tire info on it. Just do a search.
    Sep 2007
    Wilmington, NC
    13,986
    Custom Tires: http://www.dbtires.com/
    RubirosaGGatsby is offline Cadillac Owners Member
    Automobile(s): DTS
    Jan 2013
    42
    I've seen some shops that will "make" (I'm assuming a paint of some sort) a white wall tire for you. They took 24 inch tires and made them to resemble Vogues--some with different colors in place of the traditional mustard. I'm guessing they did it because Vogues don't come in that size. However, a shop that can do that can certainly do that on a 17 inch tire of the size you want, too. Unfortunately, I'm not sure of the price and can't recall the name of the shop I saw doing it, but there's bound to be one in your area if you decide to go that route.
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    Chris has a good idea here. I'm going to check with Diamondback about putting a thin whitewall on the Michelin Primacy. That is, if the Primacys I have now ever wear out!
    Jan 2005
    NC
    436
    I saw some painted on WSW on a mid-90's DeVille tonight. Looks OK at a distance, a little ragged on the edges up close. The white went right up to the wheel rim, unlike factory whitewalls.
    Automobile(s): DTS
    Jan 2013
    42
    Here's an example of the custom white (or any color) wall I mentioned above.
  13. Remove Advertisements
