two questions, alignment and pressure sensor computer calibration
Results 1 to 9 of 9
Cadillac DTS Forum - 2006 through 2012 Discussion, two questions, alignment and pressure sensor computer calibration in Past Cadillac Vehicle Discussion; first off is i just put some 22s on my car and its pulling a bit to the right, brand ...
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    first off is i just put some 22s on my car and its pulling a bit to the right, brand new tires, alignment done yesterday in to spec, everything has been replaced, still pulls right? wtf lol im planning on taking it back, and another issue is my pressure sensors do not like 39 psi which is crazy to me, i wanna go get the computer set at 42-45 high, how much has anybody been charged to use the tech 2?
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Re: two questions, alignment and pressure sensor computer calibration
    Why are you running 39 psi in 22" tires? Your ride must be very harsh.
    Don
    Oct 2012
    32
    255
    Not at all actually the ride is better than the 235/50/18s I was running.
    You don't want the psi low damage to the rim is easier with the low psi. I just can't believe the warning comes on for 38ish psi you would think 26-45
    And the dealership by me wants 94$ to reprogram the computer ugh
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    I am no tire engineer, or even an expert, but I would think dropping the psi should be better on the wheels. Lower pressure should soften the sidewall some and allow some "cushion" for potholes and such. The higher the pressure stiffens the sidewall which I would think generates more energy to the wheel during an impact. Just my theory not a rule.
    Don
    Oct 2012
    32
    255
    That .makes sense. But I'm still boggled by the low high warning. I start off in the morning 35. And 10 minutes into driving they hit 40. Crazy. I just wanted a little buffer
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by big greg View Post
    Mine have been at 40 lots of times and they do not come on, but I have the Performance Sedan.
    Max pressure for the tires is 44psi...
    I run 35 / 36 cold.
    I do not know what the max pressure is that mine are set on.
    On the LOW pressure side, they come on at 27 psi.
    Oct 2012
    32
    255
    Just earlier they came on at 38. So I'm probably gonna cough up the dough to get it calibrated. Unless I can convince the snap on guy to borrow a scanner lol
    CaddyMAK is offline Cadillac Owners Fanatic
    Automobile(s): DTS 2006
    Nov 2011
    198
    Quote Originally Posted by Superjim View Post
    I run 35 / 36 cold.
    Mine come on at 25 or 26. When I just had my new set of Primacys installed about a month ago the tech had them at like 38 psi...soon the message came on for the tire pressure. Is it bad to have it higher than the recommended 30 psi? I mean would it cause premature wear or something? Because the feel is better when the psi's are higher.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by CaddyMAK View Post
    I would suggest trying 32 or 33 psi...
    That way when the tires heat up from driving, it won't set off the TPMS, and it will still feel better than 30psi.
  12. Remove Advertisements
