Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: What speed does your DTS shift into D/OD?
    billdaman is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS
    Oct 2010
    NeW York
    226
    I just noticed today that my DTS will only shift into D/OD at speeds in excess of 42 MPH. It doesn't matter if I let off the gas or maintain speed. I need to hit / maintain at least 42 before it shifts into D. Once it hits D it will stay there unless I slow dramatically, or accelerate enough to make it downshift.
    My other 2 GM vehicles (Avalanche and Envoy) shift into D/OD much sooner, as early as 25 mph if I pull off the throttle.
    Anyone else see a different speed to go into D on their DTS?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: What speed does your DTS shift into D/OD?
    Mine USED TO shift at 41....
    From what I have read... that is normal for the DTS.
    I reset mine to shift into 4th at 36mph AND have the torque converter also lock up at 36.
    I like it a lot better that way.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Shift points are dynamic, there is no 1 speed at which each gear change occurs.
  5. #4
    Oct 2010
    NeW York
    226
    That's what I thought until this weekend, but its not dynamic in my vehicle in "Normal" driving, 40 deg temperatures , car loaded or unloaded it is consistent. I tried at least 20 times and couldn't get it to shift before 42 mph
  6. #5
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    The specs in the Transmission Control Module control the MINIMUM SPEED that it will shift...
  7. #6
    Oct 2010
    NeW York
    226
    Quote Originally Posted by Superjim View Post
    Jim, I need that shift profile in my DTS!
  8. #7
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by billdaman View Post
    The TCM can be reprogrammed at any "GOOD" speed shop that uses EFI Live or HP Tuners software.
  9. #8
    danog is online now Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    443
    Shift Speed
    Hydra-Matic 4T80-E Shift Speed Chart
    12 Shift@ +/− 3 mph
    23 Shift @ +/− 4 mph
    34 Shift@ +/− 5 mph
    4-3 Coast Down shift @ +/− 4 mph
    3-2 Coast Down shift @ +/− 4 mph
    2-1 Coast Down shift @ +/− 4 mph
    VCC Apply 4th Gear
    % of TPS
    10
    25
    50
    10
    25
    50
    10
    25
    50
    Model
    Series
    AAN
    K
    8
    18
    37
    14
    34
    68
    23
    55
    112
    35
    16
    7
    42
    MLN
    K
    7
    15
    33
    12
    28
    56
    18
    45
    93
    35
    14
    6
    36
  10. #9
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    mine is the same as bildaman's. shifts into O/D at 42 mph. Letting completely off the throttle at any speed below 42 will not get it to upshift. I think it's programmed that way so it won't lug. Local traffic around here runs about 38 - 40 mph, so it's frustrating to be driving in third all the time. I was hoping Jim would tell us how his tune job affected this. Now I know it can be fixed, I'll just have to pry open my wallet and get it done.
  11. #10
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    O/D is 4th gear - it's about a 0.68:1 ratio. 3rd is the 1.00:1 gear. TCC (Torque Converter Clutch) drops out that last 300 or so of rpm slip above 42 mph or so. TCC/VCC is the fuel mileage - emissions bugaboo that afflicts so many earlier 4T80E transmissions, either through a P 0741 (TCC stuck off) or P 1860 (TCC solenoid or circuit) fault. Two successive start-run-drive cycles during which either code sets and you get a SES light and the car will fail emissions.
    Get to a road on which you can easily run at 45 - 50 mph. TCC/VCC engaged. Holding speed with your right foot, lightly touch the brake pedal with your left - TCC should drop out and engine rpm increase by about 300. Take your left foot away from the brake pedal and TCC once again engages. TCC also drops out at some throttle opening that requires more than a tad of power increase. When you have your gas pedal foot stuck through the firewall for max acceleration TCC will NEVER engage.
  12. #11
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by tightwad View Post
    When I had it changed from 42 mph to 36 mph... I liked it SO MUCH better...
    It made a big difference to the overall feel of the car when you are only going around 40.
    If you are using real light throttle, the TCC will also engage after a few seconds.
    If you start giving it a little gas the TCC will unlock... if you give it MORE gas it smoothly goes back to 3rd gear... then as soon as you ease up on the gas, it shifts back to 4th and the TCC locks up again.
    I have driven loaners when mine was being serviced...
    I was always glad to get my car back.
    In my opinion, all of them should be set to go to 4th gear at a lower speed than 42.
    Jim
  13. #12
    Feb 2006
    56,868
    The kicker is that the Northstar is a little engine that needs RPM to develop power. The TCC engagement speed was developed to be a "happy medium" between RPM drop (fuel savings) and RPM operating range (power band).
    Remember - this puppy is a tad smaller than a 1964 Chevy 283 !
  14. #13
    stormnn's Avatar
    stormnn is offline Cadillac Owners Fanatic
    Automobile(s): 06 Cadillac DTS
    Sep 2008
    Bowmanville Ont. Leesburg Fl.
    73
    278
    My 06 shifts at 42 under light throttle. what's wrong with it staying in 3rd below that speed? Makes it more responsive.
    Norm
  15. #14
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    My '08 Performance shifts into OD, while under very light throttle, at 38 mph.
    Don
  16. #15
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by Submariner409 View Post
    At 36 if I stand on it, it INSTANTLY drops all the way back to 1st gear and is at about 4000 RPM...
    Mine doesn't have the PAUSE/HESITATION that most of them have when changing gears.
    The pause and accompanying timing retard to make it shift smooth along with the 1/2 second shift times have been eliminated on my car.
    I reckon it's just a personal thing... I just like it to shift earlier if I am not in a hurry.
    If I AM in a hurry... it doesn't shift from 1st to 2nd till 7000 RPM.
    Then I want it to shift FAST, from one gear to the next.
  • You may not post replies
