Upper Spring Insulator
Results 1 to 2 of 2
Cadillac DTS Forum - 2006 through 2012 Discussion, Upper Spring Insulator in Past Cadillac Vehicle Discussion; I had my strut mounts changed out again after the Monroe strut mate mount kit part number was pulled for ...
    CaddyMAK is offline Cadillac Owners Fanatic
    Automobile(s): DTS 2006
    Nov 2011
    198
    I had my strut mounts changed out again after the Monroe strut mate mount kit part number was pulled for our model. Now I am almost certain that the upper spring insulator/washer (or whatever it is called) is not longer on the current setup. A steering issue emerged in which my steering wheel is sloppy and there is poor returnability (especially when turning left). Mechanics are saying nothing is broken and everything is in order. I know the insulator's role is to reduce noise but I've read that it also allows the spring to sit squarely on the bearing. Can the insulator affect the steering since it sits between the coil and the bearing?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    No.
    Check that the new mounts were tightened securely.
