07 DTS high speed steering wheel wobble and passenger copartment shaking
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac DTS Forum - 2006 through 2012 Discussion, 07 DTS high speed steering wheel wobble and passenger copartment shaking in Past Cadillac Vehicle Discussion; 07 DTS 82k at speeds between 65 & 75 the steering wheel will wobble slightly and you an see the ...
    jonsab is offline Cadillac Owners Member
    Automobile(s): 2007 DTS
    Mar 2013
    8
    07 DTS 82k at speeds between 65 & 75 the steering wheel will wobble slightly and you an see the vibration in the passenger seat....At lower and higher speeds there is no vibrating sensation. Any Ideas?
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    679
    Re: 07 DTS high speed steering wheel wobble and passenger copartment shaking
    Have you're tires Road Force Balanced, Our DTS are very finicky about this.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Welcome, jonsab! If you would ever like me to look into concerns further for you, please email me at Katie_Lucille@gmexpert.com. I'm happy to investigate and/or call your dealer on your behalf to schedule an appointment.
    Best,
    Katie
    Mar 2013
    8
    Thank you I will contact you if needed...Funny you should ask about the dealer..changed dealers because relocated and dissatisfied so far what a shame.
    jazoo is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Jun 2012
    365
    Quote Originally Posted by jonsab View Post
    There could be several reasons for the steering wheel wobble; i.e. improper tire pressure, one of the front wheels bent/damaged, tire(s) cupping, worn out strut(s), out-of-balance wheels, etc. So how long you had this Caddy and when was last time you had the wheels balanced dynamically? When did you get the four-wheel alignment and front-end inspection by an experienced mechanic? How many miles have been logged on the existing tires?
    Jonsab, I would get the tires rotated first and then see if the problem persist. If yes, then I would get the four-wheel alignment done and the front end inspected by your local reputable auto shop.
    Mar 2013
    8
    The issue has come down to that all four rims are slightly bent. A road force balance has been done the rack has been replaced an alignment and inspection was done. The rotors and front breaks and rear were replaced. It has improved just slightly. I do not have four tires and rims to experiment with. At this point I will just have to live with it. It has 83k on as of now.
    Jul 2012
    Ontario, Canada
    679
    Checking you're torque mount strut ( I think that is what it is called ) under you're hood near the coolant tank. Two bolts with rubber mounts that can crack. Some guys on the board have noticed cracks replaced the mount $49.99 and has helped with vibrations. There is a good thread and pictures of it somewhere here. I hope this might help.
    Mar 2013
    8
    That is a great idea. I will look into that.
    cadwolf is offline Cadillac Owners Member
    Automobile(s): 2006 dts
    Jun 2009
    40
    26
    i recently had same issue.changed wheel hub assembly didnt work.changed torque strut mount {llos like engine mount next to coolant resevoir}that didnt help the vibration got a little less.changed brakes and front rotors no help.4 new tires no help.then my friend said let me balance the tires he spent a good amount of time balancing got them perfect,would you believe vibration is gone.in my experience if there is an issue with yor rims and tires thats what is causing the problem.these cars are ver sensitive to wheel balancing.by the way mine is a 2006 dts performance with 71k
    Jul 2012
    Ontario, Canada
    679
    cadwolf you're bang on a pro shop that can road force balance is peace of mind.
    Jun 2012
    365
    If you got a clean bill of health on the tires (no cupping, feathering or separation) and the rims then I would suggest to to rotate the tires and see if the wobbling or shaking go away. You can do the tires rotation yourself.
    Mar 2013
    8
    The dealer said they put the most bent rims on the back. When the road force balance was done. I just do not think the dealer will let me test four rims and tires from another car. I feel that would elminate any doubt about the wobble is coming from the rims. If the dealer is truly telling the truth about the rims being bent. Is there any way just by balancing the tires could solve the issue or is swapping the tires and rims the only solution left?
    Any chance your balencing friend is in NJ? LOL
    stormnn's Avatar
    stormnn is offline Cadillac Owners Fanatic
    Automobile(s): 06 Cadillac DTS
    Sep 2008
    Bowmanville Ont. Leesburg Fl.
    73
    278
    Cadillac rims don't just bend. The car would have be pounded over a curb or something simular to bend them. I had 1 bent rim on mine when I bought it used, found a dealer with a rim straightner & it was like new again. Then with new Michelins the car is perfect smooth again.
    Norm
  16. #14
    Jun 2012
    365
    [QUOTE=jonsab;3256877]The dealer said they put the most bent rims on the back. When the road force balance was done. I just do not think the dealer will let me test four rims and tires from another car. I feel that would elminate any doubt about the wobble is coming from the rims. If the dealer is truly telling the truth about the rims being bent. Is there any way just by balancing the tires could solve the issue or is swapping the tires and rims the only solution left?[COLOR="Silver"]
    I do not fully understand/comprehend the the condition of your Caddy's rims. My gosh, how many bent/damaged rims you are talking about? How did you acquire this vehicle and how many on it? I am like stormnn, that the rims don't bend easily unless they were abused. Unless you replace/repair the rims, you have no way of knowing the root cause of the problem. You can try the solution proposed by stormnn as it is still cheaper than repairing all damaged rims or buying new ones. On the other hand, the cheapest/frugal way would be to keep on driving especially when you are still unsure even after several folks gave you their ideas.
    GOOD LUCK & HAPPY DRIVING!!!
  17. #15
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    I bent a front wheel slightly in my DeVille in January in a pot hole at 50 mph, enough to cause a little side-to-side motion at very low speed, but it was largely undetectable at higher speeds.. My mechanic put it on the back. Oddly, the wheel hub on the other side also needed replacing.
  18. Remove Advertisements
