alignment problems on 2007 DTS
Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By tightwad
Cadillac DTS Forum - 2006 through 2012 Discussion, alignment problems on 2007 DTS in Past Cadillac Vehicle Discussion; Had the DTS aligned last April. Shouldn't have. Since then it veers left an will be in other lane in ...
    tom3998 is offline Cadillac Owners Member
    Automobile(s): 2007 dts
    May 2010
    11
    Had the DTS aligned last April. Shouldn't have. Since then it veers left an will be in other lane in 3 secs. Took it back to dealer who told me to change left tire. Ha Ha HA. Put on new tires recently and still veers left. Even rotated left (drivers) tires, and still veers. What's wrong? I think it should be re-aligned once a year anyway.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: alignment problems on 2007 DTS
    Mine has never had an alignment...
    2006 with almost 127,000 miles.
    The tires wear evenly so I don't figure it needs it.
    My Grandpa used to say... "Boy, if it AIN'T BROKE... don't go FIXING IT...
    Texas Jim
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    Newer cars are really better than they were in the good old days. Used to be that weak frames, sagging springs and quickly wearing parts made wheel alignments a common thing. Now-a-days, you probably only need an alignment if you have a too-close encounter with a pothole or curb. Get used to the way your car drives and feels, and it will tell you when there's a problem. If the steering wheel goes off-center, that's a big tip-off.
    In your case, I think the alignment job you got was probably a lemon. While this kind of problem can be caused by bad brakes, I would bet the cross-caster is off. The caster is not the same on both sides. This can cause some really squirelly behavior, but usually doesn't cause any tire wear. Ask around and find a good shop and get the job done over. Get them to ride with you so they can see what's going on.
    tom3998 and tom3998 like this.
