Results 1 to 11 of 11
Thread: Won't start
    Gomaz's Avatar
    Gomaz is offline Cadillac Owners Fanatic
    Automobile(s): 2009 DTS II
    Jun 2010
    Canada
    164
    Won't start
    So today I tried to start the car and it will turn over and try to start but it just won't catch. There is plenty of gas in the car. I even tried the remote starter but it just turns over and over and thats it. a few times the motor will catch but it will not stay running long enough for me to give it gas. Sounds like the fuel pump to me. What do u guys think?
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    Look at the fuel pump relay and fuse 08 and newer have a big problem with the fuse box under the rear seat. If the relay is burn go to if you have it in your town to autozone buy the relay it is the same for the deville and the dts. I have couple of friend that happen to them. The car is going to star but it will keep burning the relay until you change the fuse box. Hope the car still under warranty good lk.
    TulsaVic is offline Cadillac Owners Enthusiast
    Automobile(s): '08 DTS Performance (gone); '11 Jeep Grand Cherokee Summit; 2017 MB C300 Cabriolet
    Jan 2008
    Harrison, ME
    69
    823
    Re: Won't start
    Since a bad crank sensor will cut the fuel when the car is running, will it also prevent fuel flow when starting the engine? That sensor seems to be a relatively common problem....
  5. #4
    Gomaz's Avatar
    Jun 2010
    Canada
    164
    Re: Won't start
    I have no warranty left, just powertrain, not sure that this will fall under powertrain
  6. #5
    Gomaz's Avatar
    Jun 2010
    Canada
    164
    Re: Won't start
    So..I took car to dealer and was told that the water pump is covered under the powertrain warranty but it is not the fuel pump, its teh relay. lucky it is just $152 CND to fix
  7. #6
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Won't start
    Quote Originally Posted by Gomaz View Post
    For $152... all they did was replace the relay...
    Your problem WILL return...
  8. #7
    Mar 2010
    Detroit, USA
    12,709
    Re: Won't start
    Gomaz, thank you for posting your dealer's resolution! If you ever would like to involve the Customer Service team nearest you, I wanted to make sure you had GM of Canada's contact information. http://www.gm.ca/gm/english/corporat...actus/overview gives you not only their hotline details but also their means of online communication!
    Best,
    Katie
    Cadillac Customer Service
  9. #8
    grullon10's Avatar
    Dec 2012
    46
    553
    If they charge you 150 for that cost $30 they are bad the problem will come back. The problem is the fuse box under the back seat.
  10. #9
    Gomaz's Avatar
    Jun 2010
    Canada
    164
    Re: Won't start
    shit well that sucks. so should i get the fuse box looked at?
  11. #10
    Gomaz's Avatar
    Jun 2010
    Canada
    164
    Re: Won't start
    I forgot to get the fuse box looked at and guess what.... car won't start again. Its at the shop now, how much to get fuse box fixed?
  12. #11
    Gomaz's Avatar
    Jun 2010
    Canada
    164
    Re: Won't start
    Just left from the shop and they re-wired the relay and got be a new relay. This way I don't need to replace the fuse box at $549 CND. Issue resloved (I hope) for $140 taxes in.
  • You may not post replies
