Results 1 to 12 of 12
Thread: p0411 incorrect air flow
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    Like I said before I had spend a lot of money trying to correct this problem. I posting this is because I'm to spend another 200 to 500 bucks by changing the exhaust manifold. Any ideal.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: p0411 incorrect air flow
    I don't know what is causing it, but I have very serious doubts it is the exhaust manifold...
    grullon10's Avatar
    Dec 2012
    46
    553
    Doing that is one of the last thing I could to fix it. I have follow every step that gm reconmend to do we even reprogram the ecm. The next 3 steps are change the intake and right side exhuast manifold or change the engine. That exhuast manifold on the top it has a track the fresh air gos into the motor when the pump is on. On the last test that I did we compare my 06 dts with an 08 the only different was with the pump off the baro pressure and the air presure were the same with the pump on my 06dts the air pressure when up 25psi but on the 08 only when up 15psi.
  5. #4
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    442
    I hope you are doing this on a cold start. You answered your own question. The pressure is too high. Take of the control valve off and command it on and see if it opens up all the way. It sounds like the valve is not opening all the way. Swap the vale off the 08 for a few days.
    During phase 1, both the AIR pump and the solenoid valve are activated. Normal secondary air function occurs. Expected system pressure is 815 kPa above BARO
    The ECM determines that the difference between the predicted system pressure and the actual system pressure is greater than 5 kPa
    OR
    The ECM determines that the difference between the predicted system pressure and the actual system pressure is less than −5 kPa.
    DTC P0411 sets during phase 1 and within 22 seconds when the above conditions are met.
  6. #5
    grullon10's Avatar
    Dec 2012
    46
    553
    It is a new valve I change it 2 month ago, thinking that was the problem and it was not.
  7. #6
    grullon10's Avatar
    Dec 2012
    46
    553
    Update nothing new it is going to cost me a lot of money to fits the problem it is a clog headvalve. If any of you have taken of one of the valvehead at the exhaust outlet they 4 small channel that bring the air from the check valve in to the motor they get plug with carbon and the only way to clean it is by removing the right side head. 06 and newer they only have one check valve the one by the fire wall. Later today I'm going to pst some pic.
  8. #7
    grullon10's Avatar
    Dec 2012
    46
    553
    Finally fits it by removing the exhaust manifold agaist the fire wall and inside the head there are 4 holes that bringe the fresh air in to the exhaust system they get clog. To clean it you have to use a small flat head screwdrive and cab cleanner is not easy.
  9. #8
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    684
    Did this finally fix you're problem, if so Great news. Way to stay with it and not give up.
  10. #9
    grullon10's Avatar
    Dec 2012
    46
    553
    Tom I had to now I don't have the money to get another one.
  11. #10
    BIGDADDYCADDY07 is offline Cadillac Owners Fanatic
    Automobile(s): 07 dts 1986 fleetwood brougham d'elegance
    Jun 2011
    BROCKTON MA
    136
    NICE WORK JOB WELL DONE
  12. #11
    Clembo is offline Cadillac Owners Member
    Automobile(s): 2009Dts
    Feb 2017
    60
    Please send me those pictures . Send to Cyardon58@gmail. Com. Thank you
  13. #12
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,808
    You will probably wait a while - the OP hasn't logged in for 3 months and this thread has been dead for 4 years.
    Please look at post dates in the username bar of each post. Your 2 later identical threads in DTS have been merged.
  • You may not post replies
