did the heated seat repair
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree2Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, did the heated seat repair in Past Cadillac Vehicle Discussion; and boy are my buns happy , although it took a pair of pliers to remove the plug from the ...
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    and boy are my buns happy , although it took a pair of pliers to remove the plug from the module, I had to break the melted plastic, I.cleaned all the plastic up, rebent the spade plug and added a bent staple been.working for a week now! I will post a couple pics when my phone let's me
    BIGDADDYCADDY07 is offline Cadillac Owners Fanatic
    Automobile(s): 07 dts 1986 fleetwood brougham d'elegance
    Jun 2011
    BROCKTON MA
    136
    Re: did the heated seat repair
    a warm bun is a happy bun
    big greg and big greg like this.
    jdalton50's Avatar
    jdalton50 is offline Cadillac Owners Member
    Automobile(s): 2007 DTS
    Dec 2012
    14
    Can't wait to see your pics... I have that same repair to make on the passenger seat.... I assume its the same repair.... buttons light up on door but no heat on seat! LOL
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    455
    A customer may commentthe heated / cooled seat feature is inop for either the driver or passengerfront seat. The cause may
    be a poor connection of the climate control seatmodule (CCSM) C1 pin E circuit 1440 (2006- 2007 model years)
    or X1 pin Ecircuit 1440 (2008 model year).
    I do about 20 to 30 a year. You don’t have to remove the seat. Take out the 2 rear bolts
    Tilt the seat back forward to unhook the front of the seat from the locking pins. Lay the seat back on the back seat.
    You can get the connector with 20in leads part number 15306171
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    GM Part: CONNECTOR
    Part NO.: 15306171
    Replaced By: 15326110
    http://www.gmpartsgiant.com/parts/gm...-15306171.html
    Price $3.34
    Nov 2011
    455
    Ya it’s been replace by just the middle connector. (The white part.) No pins, wires or outside lock connector. (The black part.)
    It was much easer to cut the connector and splice in the new wires. It makes a nicer job. Now Gm wants you to release the
    terminals and if you don’t use the right release tool you ruin the terminal. Install a new lock (the black part.) And splice in a
    new terminal replace the burnt one.
    Leave it to GM to screw up an easy job.
    Most dealers have the old connector. We got 29 in stock.
    Here is what the connector looks like with the wires.
    http://www.amazon.com/gp/product/com...au_pf_dp_chart
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    I would rather pay more and do it "RIGHT"...
    Everybody ... disregard my previous post about the part.
    Oct 2012
    32
    255
    I just did this to.make sure it wasn't my.module, and yes as danog said just remove the two torx bolts that are about 250ft lbs and locktited lol, then adjust the.seat so its easily tilted forward into the windshield and lift it out, I would have never got it unplugged without tilting the seat back because of the plug being under the motor shaft
    BIGDADDYCADDY07 likes this.
    jdalton50's Avatar
    Dec 2012
    14
    Which of the two connectors (top pic female or bottom pic male) did you replace? Or did you replace both of them? If it is the female then were the wires color coded? How did you keep the correct wire to wire connections? I see the Amazon $49 "female connector with lead". Did you use that one?
    Nov 2011
    455
    Bottom pic is the Climate Control Seat Module.
    Top PIC is the plug connector you replace. The new plug comes with all white wires,
    Line up the connectors side by side and cut one wire at a time.
    jdalton50's Avatar
    Dec 2012
    14
    Thanks! That helps! I'll give it a try.
    BobbieB is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac DTS
    Mar 2013
    6
    jeffu is offline Cadillac Owners Member
    Automobile(s): 2007 DTS LUX 3
    Jan 2014
    hello, does this part come with new connector and wires? I saw a thread were you can just cut wires and splice in new connector. Thanks!
  16. #14
    Eddie39's Avatar
    Eddie39 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS LUX II 65k - Once owned 1998 Deville & 2002 Deville
    Jun 2011
    South Carolina Lowcountry
    78
    179
    Question: Why can't you removed the bad wires from both sides of the connector and use a inline connector to make the connection instead of replacing the whole connector?
  17. #15
    Atavar is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS
    Aug 2013
    ND
    62
    211
    Personally I think that would be a better way to do it, and at the same time you could use a connector that was actually rated for the power the seat uses so the connector would not fail in the future.
  18. Remove Advertisements
