2007 DTS heated seats inoperative
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Cadillac Cust Svc
Cadillac DTS Forum - 2006 through 2012 Discussion, 2007 DTS heated seats inoperative in Past Cadillac Vehicle Discussion; My heated/cooled seats stopped operating earlier this year. When I press the on/off switch the lights come on but nothing ...
    louiephipps is offline Cadillac Owners Member
    Automobile(s): 2007 DTS
    Dec 2012
    78
    1
    My heated/cooled seats stopped operating earlier this year. When I press the on/off switch the lights come on but nothing happens. The rear heated seats work fine. I took the car to a dealer this week and they told me the problem was that a connector had melted inside the module. The repair estimate is $850 and the car is out of warranty. It seems to me that a connector melting beneath a seat could be a fire hazard. Is anyone aware of any safety recalls from Cadillac concerning this issue and if not, how do you go about reporting a safety issue?
    HASSAN4477 is offline Cadillac Owners Member
    Automobile(s): 06 DTS PERFORMANCE
    Oct 2012
    43
    Have you checked the fuse the way the dts is built they scan with a tech 2 and everything has a trouble code in most cases the dealer will not tear down the car before scanning it check your fuses first
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: 2007 DTS heated seats inoperative
    Louiephipps, I would be happy to check for any open recalls currently on your DTS. Please don't hesitate to email me at Katie_Lucille@gmexpert.com with the last eight of your VIN, and I can check my resources for any helpful information on the topic for you. (I can also contact your dealer if you would like any assistance working with them!)
    Katie
    Budda likes this.
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    428
    #PIC4825:
    Heated / Cooled Seat Inoperative -
    keywordsclimate control cool cooled driver front heat heated inoperative intermittentleft
    module passenger right - (Mar 18, 2008)
    Subject: Heated/ Cooled Seat Inoperative
    Models: 2006- 2008 Buick Lucerne w/ RPO KB6
    2006- 2008 Cadillac DTS w/ RPO KB6
    The following diagnosismight be helpful if the vehicle exhibits the symptom(s) described in this PI.
    Condition/Concern:
    A customer may commentthe heated / cooled seat feature is inop for either the driver or passengerfront seat. The cause may
    be a poor connection of the climate control seatmodule (CCSM) C1 pin E circuit 1440 (2006- 2007 model years)
    or X1 pin Ecircuit 1440 (2008 model year).
    Do about 20 to 30 a year. You don’t have to remove the seat. Take out the 2 rear bolts
    Tilt the seat back forward to unhook the front of the seat from the locking pins. Lay the seat back on the back seat.
    You can get the connector with 20in leads part number 15306171
    docofrock2000 is offline Cadillac Owners Member
    Automobile(s): '07 DTS
    Jan 2013
    1
    My wife's 2007 just did the same thing, burning smell, heating/cooling all quit, melted connector, no blown fuses. Bad news. Replacing connector, hope module is ok, reducing 30A fuse to 25A for better safety in case it hapens again.
    BobbieB is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac DTS
    Mar 2013
    6
    3XStanleyNJ is offline Cadillac Owners Member
    Oct 2013
    2006 DTS, both front seats do not function. Similar results as posted earlier, with the relay clicking when you hit
    the switch, no blown fuses...I am planning on getting involved with it this weekend. Thanks for the advise and Part number for the harness! I will post results after I dig in!
    revolcallidac is offline Cadillac Owners Member
    Automobile(s): 07 Escalade
    Aug 2013
    31
    Hey, mine did this exact same thing for a while.....at first they worked fine...then when I hit the button I'd hear the relay click, then about 3-4 seconds later it would click again and that would be it until I restarted the car. At this point, the only time my seats would heat was when it was absolutely frigid outside....below 20F, (and that can be rare here in middle TN) which let me know it was a connection issue. I'd use remote start on those really cold days and on first start up they would work...I guess the cold made them contract enough to complete the connection. Then they got to where they would not work at all. After reading and seeing pics on here I unplugged mine and found the melted connector in the exact same places. I ordered the connector for like $5 total on ebay and just now tonight I fixed them. It took me over an hour clipping, snipping, and being careful not to hurt any of the contacts inside, I was able to just pop the melted plastic off the metal, cleaned it with lacquer thinner to remove residue, and one by one placed the wires back into the new connector. They actually work now! Wonder how long it will be before the new connector melts like the old one. I didn't even have to remove the seat!!! There really should be a safety recall on these cars with this system. I filled out a complaint with NHTSA on their website. Make enough noise and they will investigate it.
    The new part # is 15326110 It's just the plastic connector, no wires...unless you get lucky and find one at your local dealership in the back room...that old # is 15306171
    If you search for the old # it will pull up the new one and say it's the replacement part #. Good luck in your endeavor...it's tedious but not impossible...and think of the money you will save!!
    Oct 2013
    Quote Originally Posted by 3XStanleyNJ
    2006 DTS, both front seats do not function. Similar results as posted earlier, with the relay clicking when you hit the switch, no blown fuses...I am planning on getting involved with it this weekend. Thanks for the advise and Part number for the harness! I will post results after I dig in!
    Found the plug burnt under the passenger seat! Working well after the repair!
    Thanks for all the posts!
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    $5.60 with free 2 day Prime shipping...
    http://www.amazon.com/s/ref=nb_sb_no...2Ck%3A15326110
    billbill1 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Aug 2011
    Liberty Mo.,Ocala Fl.
    74
    56
    Has anyone checked to see if the High Current circuit, that is burning out, can be
    pulled out from plug Group, and made up with High current connector.
    It's apparent it's a Manufacturers " fault" ( to high current on that type connector).
    Might take "Engineering" into our hands. Push On connectors are available, AWG 12-10.
    Male & Female , these are good for 20-30 amps.
    FEMALE DISCONNECT .250 X .032 12-10GA YELLOW INSULATED NYLON
    WW Grainger # MNI 10-250 DFIX
    Aug 2013
    31
    I think mine just quit again, after repairing them 2 weeks ago...smelled a strange smell last night and then they just quit again! Another GM screw-up! I second that above...I was wondering myself about some connectors that can handle the current and heat generated from the obvious resistance inside the module....something that won't melt. I wish I could solder the wires on! This makes me think of the house fires back in the late '70s early '80s from aluminum wire and incompatible screws on the plugs....causing them to overheat and start a fire. These seem to only heat up at the connection. I wonder if I could solder a piece of wire to the terminals themselves and add one of these grainger connectors inline to enable disconnection if needed.
    Aug 2013
    31
    yep, just pulled the plug and it's beginning to melt AGAIN! I'm going to try to engineer it myself if I can find the right size connector. Anybody know what size the wires are under there....I mean the big black one and the big yellow one....are they 10ga or 12ga?
  16. Remove Advertisements
