2006 Base DTS Heated seat issue
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 Base DTS Heated seat issue in Past Cadillac Vehicle Discussion; I just purchased myself a 2006 DTS for my winter beater while my 11 GT 500 is in hibernation for ...
    RBCBANKER is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Nov 2012
    42
    I just purchased myself a 2006 DTS for my winter beater while my 11 GT 500 is in hibernation for the season. I got to say I love this car!!! Not Quite my age demographic lol.
    My issue is with the heated seats, both switches light up, but no heat? Anyone had this issue?
    Thanks.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Re: 2006 Base DTS Heated seat issue
    Congrats on your DTS, RBCBANKER! Have you had a chance to check out the portion of your owners manual dealing with the heated front seats (page 1-4)? According to your manual,
    "There are three temperature settings for each feature. A
    column of three lights next to the buttons will display
    which setting the feature is in: high, medium or
    low. Three lights indicate the highest setting, two lights
    for medium and one light for the lowest setting."
    Has your heat been set to the lowest setting?
    "When you press a button, the feature will turn on at the
    highest setting. Each time you press the button, the
    feature will go down one temperature setting.
    To turn the feature off, keep pressing the button until
    the display lights turn off.
    If your vehicle has remote vehicle start and is started
    using the remote keyless entry transmitter, the front
    heated seats will be turned on to the high setting if it is
    cold outside. See “Remote Vehicle Start” under
    Remote Keyless Entry System Operation on page 2-5.
    When the key is inserted into the ignition and the
    ignition is turned on, the heated seat feature will turn
    off. To turn the heated seat feature back on, press the
    desired button."
    If you're still having concerns after consulting the manual, feel free to send me an email anytime at Katie_Lucille@gmexpert.com!
    Best,
    Katie
    Mark58 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS Performance
    Aug 2008
    69
    188
    It takes about 10 minutes before seats get warm.
    trispeed is offline Cadillac Owners Member
    Mar 2012
    58
    16
    there's a multi- connector under the passenger seat that controls BOTH heat and a/c seats (if you have that) Can't remember which one (i think it's the smaller of the two, farther back under the seat than the other) it is but raise up the passenger seat and set it all the way back and inspect the integrity of the connections. .Mine stopped working and I found one of the connectors had a slightly melted pin area most likely due to less than ideal contact. I stuffed a bent staple in there to make better contact, reconnected and a year later, still working! The seats should be pretty warm in a few minutes and really hot after 10 or so.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by Mark58 View Post
    I think I would have bad blisters on my backside after 10 minutes with mine on high.
    That sucker gets HOT...
    Jim
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    Can someone post a pic of the connector that were looking for it would be a great help thanks!
    Nov 2012
    42
    Thanks for the tips guys, but I think it's the module under pass seat? I opened it and it was black and melted inside. anyone know the GM part number?
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    440
    Big Greg
    Look here, there are pic's and part numbers.
    http://www.cadillacforums.com/forums...eat-repair.htm
    Oct 2012
    32
    255
    thanks danog I've corrected this about 1.5 months ago.thanks to your tips
    Hollywoodant is offline Cadillac Owners Member
    Jan 2013
    32
    5
    How much did the repair cost u? Because I have same problem none of my seats get hot including steering wheel
    Quote Originally Posted by big greg View Post
    Oct 2012
    32
    255
    well I just cleaned up my connection. so it didn't cost me anything although my.steering wheel always worked. do.your lights come on?
    Jan 2013
    32
    5
    Yes my lights come on but nothing gets hot...
    Oct 2012
    32
    255
    Most likely the problem is the connection
  16. #14
    Phatalac is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS LUX III
    Oct 2011
    27
    130
    Mine just stopped working smelt burning plastic and just like the last three times and poof no heated seats. third time ive had this repaired at GM, works for a few months and then melts the connector under the passenger seat. if i didnt have gmpp this could get crazy, i only have a 100dollar deductible.
  17. #15
    Oct 2012
    32
    255
    That's crazy that's all it works for with a new connector, my staple job has lasted longer lol
  18. Remove Advertisements
